No third gear.
Posted: February 11th, 2009, 9:08 am
by garretc16
So i just put a short shifter in my car on the weekend and it was great until yesterday. I can shift from 2nd into 3rd gear but when i try to down shift into 3rd from 4th or 5th it wont go. I have to shift back into 2nd then bring it into 3rd. It only does this when I am actually driving the car so when it is sitting it will shfit into 3rd fine. Also when i am driving i tried putting it into neutral and move the shfiter back and forth and then into 3rd and it still didnt work..... any ideas on the problem?
Re: No third gear.
Posted: February 11th, 2009, 4:39 pm
by Mad Cow
Did you tighten the bolt and nut that holds the shifter to the linkage enough? And are you 100% sure that your clutch isn't grabbing even a bit when you do that?
Re: No third gear.
Posted: February 11th, 2009, 11:07 pm
by garretc16
I tightened the bolt up more otnight an di still had the same problem.... and the clutch is all the way in.... not grabbing
Re: No third gear.
Posted: February 12th, 2009, 9:45 pm
by Mad Cow
That's really weird, what shifter did you get?
Re: No third gear.
Posted: February 13th, 2009, 12:38 am
by neli_nael
it sounds like your having the same problem as i am with my 2nd gear. i believe my synchros is messed up. i dont know how putting in a new shifter would do this though. i would put the old shifter back on to see if its the shifter thats the problem.
Re: No third gear.
Posted: February 16th, 2009, 2:22 pm
by garretc16
i got the shifter from my friend and he had it in his old mx3... and he said he never had a problem with it. i put the old shifter back in and it still does the same thing...
I am thinking a problem with the snychros.
Re: No third gear.
Posted: February 17th, 2009, 1:59 am
by neli_nael
time for new tranny...or rebuild if you gots the $
Re: No third gear.
Posted: February 20th, 2009, 9:15 am
by garretc16
so i had to do my wheel bearing in the front so i went ot the junk yard and just grabbed a whole new spindle.... i put in the new spindle and every thing is great. so i took it for a drive and all of a sudden my third gear is working perfect again!!!! i dont know if it is a coincidence or what??
Re: No third gear.
Posted: February 24th, 2009, 3:38 pm
by mx3boyze
Yeah it was the wheel bearing, Sometimes they cause your 3rd gear to lean out alittle bit and the only way you can shift is up not down to 3rd.
On a serious note, Its good that its working but your wheel bearing had nothing to do with it.
