Page 1 of 2
True KLZE?
Posted: October 11th, 2007, 4:00 pm
by curt
Hey, am looking at a KLZE. Was just wondering if it is a true KLZE - have heard of people getting ones that look similar but are not. So yeah, real or not real? Is there a way to check without having to check the heads?
Link: http://www.jdmtigerjapanese.com/product ... cts_id=149
Thanks!
Posted: October 11th, 2007, 5:07 pm
by solo_ryder
Looks like a KLZE to me, however, a true KLZE is a straightneck IMHO, kl31 cams are the way to go. Get a straight neck and you cant go wrong, then just buy a curved neck IM for it.
Posted: October 11th, 2007, 5:19 pm
by Smith18
yeah in my own opinion a curved neck ZE is almost like a KLDE.... might as well take your money and buy a DE and build it up.
Posted: October 11th, 2007, 6:41 pm
by 94mx3precidia
ya they pretty much covered it. you have like a 50/50 chance of it being a true klze seeing as how ull be paying for shipping and if it turns out to be a de then youl have to ship it back and gunna cost ya alot of $$$ so u might as well buy a straight nect then buy like a millenia IM and u know for sure it the real s---.
Posted: October 11th, 2007, 7:30 pm
by curt
So if I get the straight neck KLZE, and throw a curved neck intake manifold on, I won't have to swap out injectors or anything will I? It would just be bolt on right?
Posted: October 11th, 2007, 10:57 pm
by solo_ryder
Correct
Posted: October 12th, 2007, 12:07 am
by mx3autozam
All 2.5's or as i should say KL use the same injectors.
Definitly get a straight neck and swap curved neck manifold on it, make sure you get the correct throtle body for the curve neck because its 60mm compared to the k8 which is 55mm and it will affect the performance of the motor.
Posted: October 12th, 2007, 4:54 pm
by Mooneggs
mx3autozam wrote:All 2.5's or as i should say KL use the same injectors.
Doesn't the curved neck COME with the correct TB??
Posted: October 13th, 2007, 9:21 pm
by Juans_93_MX3
A straight neck can actually fit in a MX3 though with some modifications
When you guys say millenia IM, do you mean as a millenia IM from a KLZE engine (J-Spec Millenia)?
Whats the difference between a curved neck ZE and a DE I/M?
Posted: October 13th, 2007, 10:01 pm
by mx3autozam
Juans_93_MX3 wrote:A straight neck can actually fit in a MX3 though with some modifications
There is no difference!
Posted: October 14th, 2007, 12:44 pm
by Nd4SpdSe
Exactly. The curved-neck Millenia DE has square runners like a ZE, it's one of the reasons why the Millenia is rated for 170hp rather than 165hp
Posted: October 14th, 2007, 1:43 pm
by hgallegos915
Dont forget this is from tiger jap... just watch out and go look at the engine yourselfbefore buying.. or ask for pics.
Posted: October 14th, 2007, 11:48 pm
by havoc13
where in ontario are u? i got mine done in mississauga at diamond japan and they have a couple other zes sitting around i got a curved neck installed 1900 with a new timing belt and water pump and it was done in 2 days
Posted: October 15th, 2007, 12:12 pm
by mx3autozam
Nothing wrong wth Tiger Jap at all..I had probably one of teh cleanest ZE's on this entire website and it came from Tiger. I went and looked at the motor they were selling me and it was infact a true straight neck klze.
Posted: October 15th, 2007, 12:13 pm
by mx3autozam
I've known people to buy a Curve neck manifold used and it never had a throtle body, sure you can use a k8 but its smaller.
