Intake manifold removed, passage to vavle filled with gas.
Posted: May 21st, 2007, 1:30 am
by studboy13
So I took of my intake manifold to clean it today, and when i removed it, two of my 6 passages to my valves, i dont know what there called, were filled to the top with gas. the gas wouldnt run for more than 2 or 3 seconds before that, this isnt normal is it? I need to clean out my valves, dont I? Is there an easier way to do anything about this? and what caused this?
Posted: May 21st, 2007, 3:25 am
by hgallegos915
hmm thats strange.. kinda of reminds mke of the situation i had. I dont know why or how... but it seems that when my car cought fire this happened... its a hypothesis.
The Fuel pressure regulator failed, fille dim with fuel, fuel somehow squirted out of the runners got spark from by arching plug wires and BOOM..
why do I say that Because it tried to happen again. After the fire I used the same regulator.. car wouldnt start, cranked and checked and yup fuel was leaking out of the IM runner.. and the bolts were torqued.. odd, replaced the regulator and its good to go.
Basically im saying check the FPR, does the car run fine?
Posted: May 21st, 2007, 6:51 pm
by Zoso124
Are you sure you not talking the fuel injectors? You shouldn't get much leakage from them. Yes you'll have a little, but its possible they could be sticking.
Posted: May 21st, 2007, 11:02 pm
by PATDIESEL
holy, Zoso- I haven't seen you post in a month of Sundays! :shock:
Not on topic, sorry.
Posted: May 21st, 2007, 11:48 pm
by studboy13
i think the valves r would thatt do it?
Posted: May 22nd, 2007, 10:42 am
by Zoso124
You got two bad injectors, you should be able to buy a set of used fuel rails with the injectors still in them for $20 in the For Sale Forum. Are you sure you didn't accidentally leak fuel down in them after you disconnected the fuel lines? which cylinders are they?
-Pat, I'm always watching! 8)
Posted: May 22nd, 2007, 10:55 am
by babyblueMX3
could also be 2 bad bottom o-rings on the injectors, happened to me before
Inspect the injector o-rings carefully for cracks.
Posted: May 24th, 2007, 10:30 pm
by studboy13
its a V6, so on the three farthest away, its the two to the right if ur looking at the car + - -
the two dashes above
