satalitte radios
Posted: September 23rd, 2006, 4:17 pm
by mx3stylez
i have been trying to figure out the best place to mount this thing, and can't decide. there is simply no place on our dash ('96) to put these, and i refuse to put it up on the window. any suggestions, with pics, would be helpful
Posted: September 23rd, 2006, 5:46 pm
by lakersfan1
Are you using a portable one with a cigatette lighter power cord, or is it more a permanent mount?
I couldn't get reception with the antenna anywhere, so I had to stick it to the roof just above the driver windshield. I run the cord through the driver door (weather strip holds it down) nad run the cord on top of my sin visors to hold it up.
Posted: September 23rd, 2006, 6:00 pm
by Dali
ive got the cnet controlled one for the clarion :) just depends on which unit you have.
Posted: September 24th, 2006, 3:08 pm
by mx3stylez
its a serius starmate. i wanted to hardwire it in for a permanite install.
Posted: September 24th, 2006, 4:03 pm
by chew*
top of roof next to windshield dead center is best place for reception, an alternative location is at the rear top of the hatch.
Posted: September 24th, 2006, 8:19 pm
by lakersfan1
What I'd do for hardwiring one in would be ditch the factory antenna above the driver's door and run the wire where the factory antenna went. Use some silcone underneath to seal the water out of that hole. Once you start satelite radio, you'll never want to tune into regular radio again anyways. The only local channel I listen to anymore that's actually on the airwaves is ESPN Radio, which I get on XM Radio anyways.
Posted: September 24th, 2006, 9:04 pm
by Dali
the sat antenna end will not fit down the a pillar, only way i could see doing it this way would be to cut the end off and replace it after you run it. only thing is you will not be able to move it afterwards.
Posted: September 24th, 2006, 10:33 pm
by mx3stylez
i actually got my antena shaved when i got the rest of the body work done, i may through the hatch, or would under the hood be a good spot too? as for the head unit, what have you guys done with that?
