oil temp gauge
Posted: December 20th, 2005, 9:04 pm
by NOTHING
wondering if anybodys installed an oil temp gauge on a v6 if so where did u put the temp sensor
Re: oil temp gauge
Posted: December 20th, 2005, 9:34 pm
by jschrauwen
NOTHING wrote:wondering if anybodys installed an oil temp gauge on a v6 if so where did u put the temp sensor
I believe it would be in a similar manner to this;
*edited correction*
http://www.mx-3.com/phpbb2/viewtopic.ph ... 11&start=0
Posted: December 21st, 2005, 12:54 am
by PATDIESEL
Your link J-Beef, bring me to the search page (input search paramters)
Posted: December 21st, 2005, 4:33 am
by jschrauwen
PATDIESEL wrote:Your link J-Beef, bring me to the search page (input search paramters)
Sorry Pat, correction made.
Posted: December 21st, 2005, 9:09 pm
by NOTHING
an oil pressure gauge is different from an oil temp gauge all cars already have an oil pressure switch u can just use that fitting 2 install the new sensor, and the water temp gauge also has a fitting 2 install the sensor, but since our engines dont have an oil temp gauge i waswondering if anybody knew of a spot that has an oil fitting besides the oil pressure sensor switch
Posted: December 23rd, 2005, 2:29 pm
by Vanished
yeah its just above the oil pan a real b---- to get out. Mine was leaking so i had to replace it. I coudlnt' find the right wrench size and its so fricken crammed good luck.
Posted: December 23rd, 2005, 3:25 pm
by jschrauwen
NOTHING wrote:all cars already have an oil pressure switch u can just use that fitting 2 install the new sensor
My point exactly - to piggy back with the use of a dual output adapter, an oil temp sensor.
Posted: December 23rd, 2005, 10:20 pm
by slimmyslim1420
Where is the oil fitting located on the engine that runs to the oil light?
Posted: December 24th, 2005, 12:56 am
by jschrauwen
slimmyslim1420 wrote:Where is the oil fitting located on the engine that runs to the oil light?
Is it not in the link?
Posted: December 24th, 2005, 9:06 pm
by slimmyslim1420
Well one part says its on the back of the block. Then that guy said if the fitting was too long it would hit the a/c fan housing so that would mean it was on the front of the block. No one indicates exactly where it is. And from everyones different posts its kinda confusing. I haven't yet looked on my engine for it, though if I did I may be able to find it that way.
thanks, Damon
Posted: December 24th, 2005, 10:20 pm
by jschrauwen
By the oil filter/cooler, front of engine. That's the one referred to in the link. "Vanished", may be referring to a secondary access plug on the rear of the engine, but I've not seen one in the manual.
