Foggy Headlights
Posted: November 27th, 2003, 8:47 pm
by my_other_ride_is_your_mom
You guys must have some remedies to this common problem. One of my covers has become almost usless because its so cloudy. What can i use on it after i get the cover off?
Re: Foggy Headlights
Posted: November 27th, 2003, 10:43 pm
by Jutzi420
I use meguiars scratch-x and platic polish. If you wanna take the lense off your light then just pop it in the oven @ about 200F for 10 minutes and pry it open with a flat scew driver.
Posted: November 27th, 2003, 10:51 pm
by babyblueMX3
you shouldn't have to take your lens off...before you do that...jsut try some autosol metal polish on your headlight..I'm pretty much sure most of the yellowish will be gone..it worked for me
Posted: November 27th, 2003, 11:25 pm
by back alley
after a good cleaning with a plastic cleaner or rubbing compound try applying some clear acrylic floor wax to the headlights. it fills in the small scratches and helps to 'clear' up the headlight even more.
