Help PLzzz Help!!
Posted: May 2nd, 2004, 5:49 am
by Mx3 Legend
Hi, I'm having problem with the lights on my car to be my specific the dash and tail light won't come on but everything else works fine..when I push on the brake the lights comes on, I don't understand what the problem is My headlight works when I turn on the lights but dash and tail light don't..And theres no blown fuel, I checked all of them the ones in the car and engine..If this have happen to any1 or know how to fix it, I will glady appreciate it...Hopefully some1 do before I take it to the shop I know its gonna cost me..but PLZ HELP!
Re: Help PLzzz Help!!
Posted: May 7th, 2004, 1:21 pm
by Nallboy
Maybe your rear bulbs are burnt, at least halfway (they have two modes or whatever). Not sure, dude.
Posted: May 7th, 2004, 4:30 pm
by drift
I know you said you checked them, but ry changing out the fuse anyway. Sometimes a fuse can blow and you might not be able to tell.
Posted: May 7th, 2004, 5:47 pm
by OsoSlo z28
possible there's a fault in the switch.
Posted: May 11th, 2004, 3:11 pm
by mx3grlsikride
did u happen to touch any of the wires that go into the deck? i had this same problem with my car right after I hooked up the new deck. turns out that the mx3's when u turn on the dash lights the deck lights come on to so they are connected. check the wires leading to the deck and make sure they are wired properlly. can't remember exactly which wire it was but shouldn't be to hard to figure out, this should be the problem cuz no my lights are fine and no problems since Good luck
Posted: May 12th, 2004, 12:33 am
by Nallboy
The red wire with the black stripe is for the illumination.
