water pump
natedwag03
water pump
i have a question,i have 92 mx-3 GS, Do i have to drain the fluid when i change the water pump? and how long it takes to change the water pump?
92 Mazda Mx-3 V6 GS
pelado
Re: water pump
Two and a half days.<p>You don't have to drain the fluid but it makes less of a mess if you do.
natedwag03
Re: water pump
WOW i was thinking is going to take me a day or less, i guess i better get start soon.<p>
Thanx
Thanx
92 Mazda Mx-3 V6 GS
