Page 38 of 51
Re: Sam's 1.6 MX-3- LT Turbo project
Posted: July 12th, 2012, 12:22 pm
by youdirtyfox
Cheers Bro I think I saw your car on cardomain btw as the spec. list was the same as your sig. Good luck with your more boost too :D
Got one nice meaty flange to play with today...along with the studs to be tapped in there.
Also my buddy hooked me up with lots of leftover boost pipes from his Miata conversion, one being perfect to get to the TB as I did wonder how I was going to do that.
and a B6 exhaust manifold gasket He had too > nice to know that I have the right mani.
Been bidding on a few Turbos, but keep missing out to snipers gggrrrrr but Im hopefull to win one soon then I can progress some more
Posted: July 12th, 2012, 12:41 pm
by mazdamx3bds
The cardomain page for my car should still be up although I haven't updated it in a long time, should still have some pics for you to see throughout the original stages of the project. I really need to do a better job of taking pics and making notes of the various modifications like you have done.
Here is the link (hasnt been updated since 2007 though and a lot has changed since then)
http://www.cardomain.com/ride/310985
Posted: July 13th, 2012, 11:39 am
by youdirtyfox
Its a cool car look forward to seeing a few more pics, I guess I just like taking alot but its all good for ref. and to show other people
different methods of how things can be done, plus everybody loves pics :lol:
Got the other flange this morning so it can all be welded up now along with fixing the broken stud.
Not the final height by the way, going to machine down the barrel so its just tall enough for clearence to weld
and to get the nuts on.
Pukka pipe :D can now work out where to sit the dump valve, and new elbow for the IACV.
I did have one question> you know the small 3mm(ish) vacuum hose that comes of from the air filter pipe and goes to those steel pipes round the back of the inlet manifold, when turboing does that stay on the pipe for the air filter or does it get moved to the cold side of the boost pipe?!
Posted: July 13th, 2012, 1:17 pm
by Josh
Coming along nicely Sam!
that VJ14 should do just nicely, you can always do a VJ14/VJ16 hybrid :shrug: one thing you might consider doing is port matching the exhaust manifold. from what I remember is there is almost a 1/2" you can take out of the ends of each port.
look forward to seeing this mod done.
Posted: July 13th, 2012, 3:22 pm
by youdirtyfox
Thanks Josh it is slowly but surely. I will look into that port matching for sure we have a die grinder at work I can use :D
Yep hybrid for sure in the future as a T28 is basically a hybrid T25/T3 turbo . T25 turbine + T3 compressor.
Posted: July 13th, 2012, 5:41 pm
by Evo_Spec
youdirtyfox wrote:I did have one question> you know the small 3mm(ish) vacuum hose that comes of from the air filter pipe and goes to those steel pipes round the back of the inlet manifold, when turboing does that stay on the pipe for the air filter or does it get moved to the cold side of the boost pipe?!
your engine bay looks so nice with the aluminum reservoir and stuff =)
if i'm thinking about the same one as you, doesn't it normally connect the valve cover port to the intake?
if i'm talking about the right one since you have the filter on there you won't need it and i used it for my wastegate.
Posted: July 13th, 2012, 6:05 pm
by youdirtyfox
Thanks Man needs a polish up really, just have not got round to it! should look even better once the battery & fusebox are out the way and the washer bottle is under the wiper cowling :welder:
Yeah I sorted the valve cover > intake one with the breather filter, its this one that comes from the airbox(now comes of my DIY induction kit)
Posted: July 13th, 2012, 6:52 pm
by Evo_Spec
ohhh and that goes directly to the back of the manifold? (haven't had/seen a B6 in a while lol) either way you won't need it, you can use that line for a boost gauge or your BOV now.
Posted: July 14th, 2012, 1:46 am
by RS_OBD'oh_2
I connected mine to the intake pipe before the turbo.
Posted: July 14th, 2012, 3:27 am
by youdirtyfox
Evo_Spec wrote:ohhh and that goes directly to the back of the manifold? (haven't had/seen a B6 in a while lol) either way you won't need it, you can use that line for a boost gauge or your BOV now.
Not directly no, just goes to around that area where there are a bunch of pipes running parralel to it. Boost guage I was going to have a little take off on the main boost pipe for it. As the MAP for the AEM is coming off from vacuum pipe from the inlet manifold to the fuel regulator and the BOV off the line to charcoal canister and thata the area I want my BOV to be right close to TB.
Thanks RS_OBD'oh_2 means I can just leave it where it else then which is on the elbow to the cone filter :D
Posted: July 14th, 2012, 3:28 am
by Evo_Spec
i didn't get any of that but yes, you do that =D
Posted: July 14th, 2012, 3:35 am
by youdirtyfox
lol sorry was I rabbiting a bit?! just had the first big coffee of the morning!
Posted: July 14th, 2012, 3:37 am
by Evo_Spec
btw, what the heck is a pukka pipe?
Posted: July 14th, 2012, 3:44 am
by youdirtyfox
Pukka means good/legit/genuine/authentic, over here there is a company who make savoury pies, called pukkapies!
I just inserted the "P' to make pukkapipes :oops: :o
Posted: July 14th, 2012, 4:41 am
by RobMinhas
At the golf course I work at, we have a company called Pukka that we get our hats from. They're quality is atrocious so I thought you meant they were crappy pipes haha.
