Sam's 1.6 MX-3- LT Turbo project.
- ethand
Re: Sam's Slammed 1.6 MX-3- LT Turbo project > Mono wiper.
Can't wiggle wiggle wiggle wiggle wiggle, yeah til the rain comes, though...
'92 JDM Eunos Presso - Zeke
- Evo_Spec
Nice job sir!
From the outside it is a little far up but i'm sure you barely see it while driving and stuff so i think it's a really cool mod, i like my 2 wipers though =)
youdirtyfox
lmao good one!ethand wrote:Can't wiggle wiggle wiggle wiggle wiggle, yeah til the rain comes, though...
Cheers Rob & Evo yeah its defo not for everyone, I have left it so its fully reversable if it wears a little thin in the winter time or whatever
youdirtyfox
The Wifes been quite busy lately with a new venture so that's given me lots of time to play with turbos
and do some research on where exactly I'm going to hook s--- into and what extra pipeage I going to need.
Over the last two days ive hit up the cooling system T pieces and oil hoses and tonight I put together
my plans for the Intercooler and boost pipes. It may end up looking a little different to this once finished and installed
Still need plenty more elbows joiners, clips etc and everything in the picture is probably not in the exact location but this is kinda the way I hope its going to play out.
I have left most of the alu pipes long so they can machined true and to size then welded.
- AaronTietje
Re: Sam's Slammed 1.6 MX-3- LT Turbo project > IC & Boost pi
Looking good as always. Do you have a "hope to be boosted by" date yet?
youdirtyfox
Nope afraid not whenever I fancy doing it really and the kit is truly ready to go on. I have my eye on some new wheels
so its got a little longer to wait yet.
youdirtyfox
Did this for my own reference and partly towards a guide for the UK peeps.
Only thing I'm not 100% on yet is the oil feed line size for unions/ length
and the water tap, Im happy with location just if I can get the right T pieces yet.
youdirtyfox
Re: Sam's 1.6 MX-3- LT Turbo project > IC & Boost pipes test
Went in how I wanted, without taking the bumper off!
- racycle
thats a pretty hidden setup
racycle's Worklog!
viewtopic.php?f=46&t=76991 -RIP
Current Toy
http://mx-3.com/phpBB3/viewtopic.php?f=7&t=80470
Please don't tap on the hood. It disturbs the gerbils.
- Evo_Spec
very nice, that's like exactly what i wanted but my GF already got me a Mishimoto intercooler =)
youdirtyfox
Stealthyracycle wrote:thats a pretty hidden setup
Cheers Evo had to be done this way as there was no way I was having long pipe runs like before on a previous car setup
Water tap T pieces ordered now and I know the length for the oil line so I will get that purchased too soon
plus a few extra silicon elbows I need.
mazdamx3bds
This project is looking great, question what turbo are you running there? The IHI-VJ14 that came with the 323 GTX 1600cc? If so I would advise against it, that turbo is way too small.
I started my project with the IHI VJ-14 which spooled quick but run out of breath really quickly, then moved to the VJ-11 off the MX-6/Ford probe which worked a bit better until moving to a bigger T-Bird turbo from the Ford Thunderbird Coupe which spools slower but pulls hard right to redline at 14-15psi.
I would advise at least a VJ-11 turbo and a bigger downpipe instead of the restrictive OEM one.
Good luck with the project and let me know if you have any questions turbo wise.
Supertech Forged Pistons, ARP Studs, ACL Bearings, Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, T3 50trim Turbo,Cone Filter, 2.5" Exhaust, 2.5" Custom Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, Megasquirt V2, RX7 460cc Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
youdirtyfox
Thanks, I'm using a VJ-11, just a good starter turbo for me really, already got plans to upgrade to a Garrett T3 much later on but I want the oil piston spray bars and electronic boost control for that
And thanks if I have anything I will ask
- Tavman_1213
I like how you moved the rad so you didn't have to cut holes in the fender well!!
93 White RS- BPT Built not bought!!
Worklog: viewtopic.php?f=46&t=78988
youdirtyfox
I didn't move it as such, its a smaller length radiator from a Ford Focus.
