Lynchz GS - Stupid Grin
- AaronTietje
Re: Lynchz GS
Those planted seat brackets are incredible. I got a set about a month ago and can't say enough about them. If anyone is going with aftermarket seats they are the way to go.
Re: Lynchz GS
i've got wedge/corbeau brackets.
looks like i'm gonna have to do a fixed bucket to get the headroom i need.
i just dont like the thought of climbing in and out. decisions decisions.
- SgtLynch
Re: Lynchz GS
Yeah the planted brackets are built like a tank. They'll last longer then the rest of the car.
Climbing in isn't so bad... it's sooooooo nice to be back in a seat that keeps me where I'm sitting. I've been tossing the car around every chance I get, it makes such a difference in control because half your energy isn't spent holding on to the wheel trying to keep yourself in the seat! You'll drive down the road with that stupid grin for a week... it's inevitable.
- AaronTietje
Re: Lynchz GS
SgtLynch wrote:Yeah the planted brackets are built like a tank. They'll last longer then the rest of the car.
I dare you to post up the grin.
Re: Lynchz GS
That hydraulic ebrake uses the OEM rear calipers?
- SgtLynch
Re: Lynchz GS
Yup. Don't think of it like an e-brake, think of it like a brake peddle for the rear brakes, thats actually more accurate to how it works.Nd4SpdSe wrote:That hydraulic ebrake uses the OEM rear calipers?
Re: Lynchz GS
Figured as much, but how does it push just the rear brakes and the fronts not getting affected?SgtLynch wrote:Yup. Don't think of it like an e-brake, think of it like a brake peddle for the rear brakes, thats actually more accurate to how it works.
- SgtLynch
Re: Lynchz GS
[quote="Nd4SpdSe]Figured as much, but how does it push just the rear brakes and the fronts not getting affected?[/quote]
Basically, your brake proportioning valve is up near the master cylendar, as long as you tap into the rear lines after that (be dumb to run the lines up there anyways) you are good.
Re: Lynchz GS
Where did you get it?
- SgtLynch
Re: Lynchz GS
Ebay. There are a mess of them on there. The particular one I got came from China. It's well built except for some slop in the handle. Home Depot nylon bushings fixed that. I know a guy with an NRG e-brake, it's nice but cost $160, I think I paid $40 + shipping. Works just as well.
- SgtLynch
Re: Lynchz GS
Updates:
Box full o' :
AN fittings/braided line/bulkhead fittings
oil sandwich adapter
fuel pressure regulator
lightweight lug nuts (spares)
splitter rods
Stuff in the works:
Repainting the Passenger Quarter and Door... thanks again for the keyjob arse!
Rollcage is being bent at CSC should be ready to weld in next week.
Pictures are way behind... I'll get to it.
Box full o' :
splitter rods
Stuff in the works:
- SgtLynch
Re: Lynchz GS - Slight Appearance change
Well, it's not Moon wax.
It's this:
Which looks like this:
Why the hell turn my car into a chalk board? Why NOT! lmao.
There is actually a logical reason for it.
It's this:
RobMinhas
Re: Lynchz GS - Slight Appearance Change
Looks awesome! I saw a picture of a couple of CRX's that were done up with the green chalkboard paint, it looked pretty cool and if you're good at using chalk you can draw up some sick designs.
I've been considering doing that. What's the texture like? Rougher than primer? Are you doing the whole car?
And what is your logical reason?
- Evo_Spec
Who's car is this? i was gonna go for a monster setup very similar to that, didn't know someone already did itSgtLynch wrote:
