Page 3 of 3
Re: UNABLE TO START
Posted: November 28th, 2004, 12:49 pm
by plusinfinit
I am sorry to hear that your car is still not starting, what i would do is check to see if my timingbelt did not break or loosened up, check to see if you get voltage at the fuel injectors. I don't know what to say but disconect the fuel line before it enters the fuel rail and see if gasoline comes out (just like the other guys said). Try disconecting your fuel pressure regulator. I don't see how the ECU will alow you to have spark and fuel but not allow you to start the engine so i have no idea about the ECU. Good luck.
