Page 12 of 22
Re: Mi|<e - 94 RS BPT
Posted: April 7th, 2010, 12:26 am
by Mi|<E
Tentative permanent places for the gauges:
Wideband and Boost Controller wired in:
I put my wideband calibration button here:
Towing for exhaust tomorrow, then off to the tuners.
Posted: April 8th, 2010, 5:38 am
by Evo_Spec
can't wait to see the results!
Posted: April 26th, 2010, 3:10 pm
by Mi|<E
Had to grab a new wastegate actuator, old one wasn't opening till 20 psi which is bad.
Just random shots of how the pipes are:
These brackets are a nice touch:
There is a small issue with the water hose inlet from the rad, its too close to the
downpipe so its being modified.
Posted: April 28th, 2010, 7:09 pm
by Mi|<E
Took some exhaust shots, forgot to get them up earlier. 2.5" with resonator
and a dynomax super turbo muffler.
The non shiney tip makes it very sleeperish. I may or may not change it later.
Front bumper support with intercooler etc fit
Posted: April 28th, 2010, 7:25 pm
by Mooneggs
This is great work... have you thought about putting the gauges in the 2 middle vents?
Posted: April 28th, 2010, 7:30 pm
by RS_OBD'oh_2
There are ideas... Something no one has done before.
Posted: April 28th, 2010, 7:33 pm
by Mi|<E
I think I may mold the autometer black gauge cups
into the sides of the vinyl where they are.
keeps all the info at one glance
Posted: April 28th, 2010, 8:55 pm
by Mooneggs
yeah I think it would be cool if someone would make a cluster with a spot for 2 gauges like that for 1 on each side for the 92-93 dash... I remember seeing a DSM with that product... I like it!
Posted: April 28th, 2010, 9:43 pm
by solo_ryder
Mooneggs wrote:yeah I think it would be cool if someone would make a cluster with a spot for 2 gauges like that for 1 on each side for the 92-93 dash... I remember seeing a DSM with that product... I like it!
DC2 Integra guys usually have that, i love the idea, and I agree that they should make em for the 92-93 dash..
Posted: April 29th, 2010, 1:09 am
by fowljesse
looking good!
Why do you need to calibrate the Wideband more than once?
Posted: April 29th, 2010, 1:36 am
by Mi|<E
Multiple reasons, mostly for accuracy. Change in altitude is the largest concern at 3438 ft above sea level
Posted: April 29th, 2010, 5:27 pm
by fowljesse
Good to know. I'm going to see if mine does it automaticly.
Posted: May 17th, 2010, 7:22 pm
by Mi|<E
4.61 psi and the lower hose blew off so its getting welded (one piece now)
170 horsepower and 159 torque, pics to follow this weekend when im less busy.
Posted: May 17th, 2010, 10:04 pm
by pox
Saweet. Need pics/vid yo!
Posted: May 19th, 2010, 7:10 pm
by Mi|<E
So the oil return has been moved from here:
To here (measured 3.5L fluid it sits just below that spot):
Preserving stock looks:
Falken Ziex 912s on some refinished GS rims:
And the all important dyno, you can see the boost was leaking then it popped
off the hot side pipe and asploded.
I have some minor things to do - front and rear motor mounts are not happy so
I have some new ones coming in. The intake needs to be plumbed over to the
driver side wheel well. And im deciding whether to run the IAC intake to the
main intake or just get a small filter and leave it up top. Also gauge permanent
placements and getting an alignment.
After that in approx 3 weeks of bombing around at 4-5 psi im taking it back for
the final tune.
