That rear subframe you are talking about comes from Jim at Pierce motorsports.. If I was allowed to change suspension pick up points in the class I race in I would buy it.. Unfortunately I have to run a stock rear subframe..wytbishop wrote:If you scan the clubprotege BG chassis suspension and brakes forum there's a thread for tubular rear subframe that one of the rally guys makes. I'm sure that he has a tubular lateral link/trailing link set up as well...but it's vague in my memory.
http://www.piercemotorsports.com/
He has tubular lateral links you can buy.. I am running a set of them on my 323.. Very good stuff.. You need to make your own custom endlinks for the sway bar, but its really easy to do with the mx3 stuff.. My end links cost me $20 to build.. here are some pictures... They are built to mx3 rear control arm lengths.. Don't mind the crummy paint job, I tried to put a rubberized coating on mine and it didn't dry completely before I installed them... (epic fail!)
