HELP car wont start when battery in the trunk WHY?
fowljesse
Re: HELP car wont start when battery in the trunk WHY?
Post by fowljesse »
Sorry it took a while. I've been really busy. Here's the grounds:
I have 2 ground wires because that's what the car came with, since it had subs. I just left them both on, and bolted them down. Can't have too much ground.The copper terminals are fpr my engine cut-off switch.
Here's the stuff bolted into the starter:
Today, I'm going to put a terminal on the end of that terrible looking one, which is the + wire from the battery. My car has a stereo whine. I'm going to put my ground wire set off my stock car on this one, since it grounds in 8 places, all around the engine.
johnmx3ze
Post by johnmx3ze »
s--- you have alot of grounds... i only have one from the starter to the chasis and one from my endine to chasis and my 0/1 gauge from the battery to the chassi... thx fowljesse
johnmx3ze
Post by johnmx3ze »
update: :P:P:P its all good guys it starts now im so f---ing happy thanks alot guys...
nolig2278
Post by nolig2278 »
i have a 4cyl with battery now in the trunk and i have burned 2 80 amp fuses so far. should i be using a higher number?
battery to fuse to starter, starter to stock fuse box,
stock fuse box to alternator.
everything in car turns on except the engine does not crank all the way before popping fuse in trunk?
do i need a higher number amp?
Thanks
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
[url=https://gilon.levinsonltd.com/mx-3.html[/url]
Ryan
Post by Ryan »
I may be mistaken, but there is no fuse between the battery and the starter. Starter can draw around 400 amps, no problem.
edit, I am not mistaken. There is no fuse.
nolig2278
Post by nolig2278 »
oh ok, i thought people used a fuse right off the battery incase the positive line got cut or in an accident
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
Newfie_dan
Post by Newfie_dan »
a starter can pull upwards of 200 amps on start up, if you are not sure what fuse to put on there put an amp clamp on it and start it under several different temps and conditions, usually for such a high draw circuit though I use a resettable breaker rated for 200 plus amps. http://firebirdsolar.com/200ampdcbreaker.html Like this one.
nolig2278
Post by nolig2278 »
i removed the fuse and it almost started.
the engine turns and i hear a clicking but I am not sure what is not working
all 5 wires of distributor are hooked up.
not sure what i am missing
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
johnmx3ze
Post by johnmx3ze »
is your battery full charged...
nolig2278
Post by nolig2278 »
i am jumping it off another car that is running
the battery has been dead for a while (platinum die hard)
currently i am clamping + jumper to battery and - to a bolt in trunk, should i find a better ground or can i clamp right to the battery?
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
johnmx3ze
Post by johnmx3ze »
charge your battery for the night and then try it in the morning...
nolig2278
Post by nolig2278 »
i wish i had a battery charger, i am pretty broke right now so
anyone know if sears will charge it up or will push starting my car work?
thanks and thanks for the info
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
nolig2278
Post by nolig2278 »
charged the battery and removed the fuse and the car started up.
Thank You all.
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
johnmx3ze
Post by johnmx3ze »
nolig2278 wrote:charged the battery and removed the fuse and the car started up.
Thank You all.
good! glad you figured it out!!! now go zoom zooming!
nolig2278
Post by nolig2278 »
running ok with the battery in the trunk, voltage is nice and stable too betweek 13 5 and 14 1 depending if load is on BUT
speaker has the whining noise that gets louder with higher RPMs and even louder with AC on.
I am searching the forums now but maybe someone can let me know.
thanks
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
