I'm no professionnel but, Those ZE engine are quite simple to go around, you either have to pay for labor or do it your self
(like any other car). Go back to basic and keep it simple at first. Have a compression test done, while doing check and replace spark plug. You will see if you have gas and you already know you have fire. If Compression is good and the engine is worth it then maybe, i would suggest physically check Timming belt and marks and that, is not a really good idea.(Have the car to to somebody who does this kind of car). And as far as I know a 92-93 ZE required a K8 disti to work, DE fits newer (I think
not sure). That kind of work is cheap parts $80 but lots of hours $$$ make sure the car worth it (They all do!!!
Those engine are not known for injecteur and fuel problem, intake or electrical (except for Disty story). They are good reliable driveable stock 175 whp engine
beware of highrev those engine and get use to engine noise
If, for any other reason your car starts, have the oil drain and filter replace, air clean Air Filter, check antifreeze and density, have other liquid top and inspect, Hit the road and have fun
