Page 2 of 3
Re: Smooth Lowering Springs??
Posted: September 26th, 2003, 4:13 pm
by Steeb
for those that dont want to read the site ive taken a couple points from lowering springs that are different from intrax sport lowering springs
http://www.intraxsuspension.com/prod_springs.html
Originally posted by ProtegeSTS:
define "smooth"
"smooth" as i would define it is controlled by the dampers, not the springs.
Intraxx still has increased rates from stock, so i have no idea how you're going to back that up.
so that just about sums it up.
1. First, the lowered look
2. The second requirement is ride quality
3.Since most of you identified that you drove 90% of your mileage to and from work, you wanted to retain some ride quality enjoyed with OE springs.
4 If you're driving to work on a racetrack, "Sport" or "Race" springs from other brands may be for you.
Posted: September 26th, 2003, 5:40 pm
by Sam Baker
LOL
yea Mr. Gro, i got what i paid for unfortunately. dropszones were just the most common on ebay (i really should stop bidding on crap) so i'm decidin now on either Intrax or Ground-Control. i've heard awesome things about intrax springs, and also about eibach (which are used on ground-controls.. and since all i've seen advertised on so many rice rockets these days are "groundcontrol" decals.. i think i might as well go with them. probably just as good either way. and YES i realize i shoulda went with a *real* company to begin with.
lata
~ sam
Posted: September 26th, 2003, 7:31 pm
by ProtegeSTS
The majority of you wouldn't have any problems with "sport springs" from most manufacturers.
I feel it's important to understand what you're doing to your car, and how it works. Gives you the knowledge to make intelligent choices the FIRST TIME and therefore, save money in the end.
400 dollars for coilovers is NOT expensive. How much are you guys spending on rims? I'm guessing some of you are easily upwards of 200 bucks a pop.
Posted: September 27th, 2003, 12:30 am
by Sam Baker
lol, i see what ya mean. and from now on i'm definitely researching BEFORE HAND so this doesnt happen again. sadly, i'm almost 19 and am just starting to learn about cars. (fortunately i have a complex car and engine to work on like the GS!!)
yea its not much $$ actually. since u get what u pay for, might as well invest in somethin good quality. :p oh another thing, is it wrong that changing all 4 struts and springs was easier than getting to the thermostat?
LOL just thot i'd add that. lata
~ sam
Posted: September 29th, 2003, 8:52 pm
by Steeb
personally i think intrax springs with zx2 struts and a rear stabilizer bar would be a good setup for comfort and good handling. imo over dampened light springs rate springs is much better for handling and comfort anyday than underdampened rugged cheap coilovers.
Posted: October 1st, 2003, 5:07 am
by quicksliver
Yah, NO! If you want a ride like a ****in' Cadillac...stay away from the ZX2 struts and big rims. You're lookin' for the mazdaspeed struts, paired with a set of ground control coilovers (not dropzones).
<small>[ October 01, 2003, 04:09 AM: Message edited by: Quick Sliver ]</small>
Posted: October 1st, 2003, 11:07 am
by Sam Baker
well i got the KYB GR-2 struts (pretty much same as stock but brand new) and was thinkin bout intrax, since some guys have said they're cool, and since they're WAY CHEAPER!! (not that its a big deal, but i just wanna save some money, if the feeling is the same between Eibach or Intrax) anybody think eibach has smoother spring rates? thanx
~ sam
Posted: October 1st, 2003, 1:38 pm
by Steeb
Originally posted by Quick Sliver:
Yah, NO! If you want a ride like a ****in' Cadillac...stay away from the ZX2 struts and big rims. You're lookin' for the mazdaspeed struts, paired with a set of ground control coilovers (not dropzones).[/QB][/QUOTE]
please expand on that if u will^
imo if i could afford mazdaspeed struts id definately get the mazdaspeed springs that they were tuned for. i doubt that the mazdaspeed struts were tuned for such high spring rates of gc's.protogests has explained it all too many times. each spring rate needs a properly tuned damper. underdampened is bad, overdampened springs should not hinder handling as underdampening would.
there are ways of getting good handling without having ride suffer from excessive spring rates for street. sway bars can help with handling enough that such high spring rates are not necessary for good handling but if you want superb handling then yah some supper stiffys and the bars would be the best with some nice struts but your ride will make your bum numb
kyb gr2 will ride ok with intrax springs im guessing but i believe they were not made for lowered cars but there are people using them in lowered cars. just be careful and dont bottom out. eibachs are supposed to be stiffer than intrax.
Posted: October 1st, 2003, 3:50 pm
by Gro Harlem
I've never heard a good thing about intrax. I rode in my buddies car who has them and they were super soft feeling, not performance-like at all.
IMO the only good springs available for this car is: grounc-control coilovers, eibach springs, H&R springs, B+G springs and suspension techniques (although i have heard of quality problems with them).
As for struts...GR2's are basically "performance" OEM replacements, not really meant for lowering. They'd work well with up to a 1" drop, but nothing greater than that. Tokico blues are good for up to a 1.5" drop.
ZX2 struts are good for a 2" drop, anything greater, and you will still blow them out. If you want to slam the **** out of your car properly, get mazdaspeed struts, not even Koni inserts will be able to withstand it, but the mazdaspeeds (made by KYB) will hold up fine, a will the GABs (which are even more expensive).
Posted: October 1st, 2003, 5:01 pm
by ProtegeSTS
konis will do fine with super low springs...
but you'll need to get them revalved when they blow.
Having less than an inch of suspension travel (what happens when you lower that much) will blow EVERY damn shock out there.
Posted: October 1st, 2003, 5:36 pm
by Sam Baker
damn.. i doubt i have any travel on my struts. O_O
i lowered it around 2" on KYB's so.... i'll probably get the zx2's. man so much trouble i've gotten myself into! -_- ok.. so what about cut springs? because that was my other option, since it is cheaper than ANYTHING. how u think it will ride? and would i still need dif. struts?
thanx.. tryin to fix what i've stupidly done, and also build up an awesome suspension/car. peace
~ sam
Posted: October 1st, 2003, 6:14 pm
by curve
If you want to try cutting the springs I have a set of stock springs I will sell you so you can have a backup if you dont like that. I think you should be happy with ground control coilovers thats what I have and I love them. Or you can use my springs to cut email me at [email]
Curve10780@aol.com" target="_blank[/email]
Posted: October 2nd, 2003, 9:00 pm
by Sam Baker
i was thinkin about cutting my springs, because its cheaper, and i did it on my last car (vw super beetle).. BUT i've heard a lotta bad things about crappy ride quality. i've ordered the zx2 struts, and what is this about the top plate of the strut?
peace
~ sam
Posted: October 2nd, 2003, 9:14 pm
by mx3man83
Cutting springs is a very touchy subject around here. I've had both good and bad experiences. With my RS, i cut quite a bit off my stock springs, so much that i had negative wheel gap with my 17's. The ride was very rough but very stiff and sporty. Handling was much better, but probaly not worth the loss in comfort level. My black GS i cut maybe 2 inches or so, about a half inch of wheel gap on the same 17's. The ride quality is only slightly stiffer than stock suspension. I am satisfied, but it's definitely not for auto crossing. The GS SE i just bought had cut springs on it already. They bounce like crazy. The ride is comfortable, but it sucks because when you hit a bump the front bounces up and down, which is a bad thing. Keep in mind, this is all on stock struts.
Posted: October 2nd, 2003, 10:24 pm
by Gro Harlem
I'm not even going to comment. So many people here don't listen to anything anyone says, and still continue to want to "cut my springs".
Most of MX-3.com = All show, no go
