You actually care about trends?wytbishop wrote:1995 called...and laughed at your Lambo doors.
Sorry man...Lambo doors are over.
vertical/suicide doors?
- _-Night-Shade-_
Re: vertical/suicide doors?
How else do I prove that I'm cooler than everyone else?
DUH...
DUH...
- MrMazda92
Hah, hah, made my day with that one.wytbishop wrote:How else do I prove that I'm cooler than everyone else?
DUH...
- MrMazda92
Oh, that makes sense... it wouldn't have any compression strength at the top, so it'd just crumple... right?fowljesse wrote:The issue is more about cuting out crucial parts of the unibody's structure. The roof, especially just above the doors, keeps the car from bending in half, drooping in the middle, and twisting. It's like a double arch style bridge.
- SpatialTerror
i think someone should do suicide doors on a mx3 with some shaved door handles. that would be sick.
if i ever get the money to blow on stuff like that i would like to do it to my gs
93 GS-R with crank pulley racing clutch and flywheel, magnaflow cat back exhaust, short ram air, 12" rockford fosgate p2 subs, on a amp 500rms, jvc touch screen deck.work log --->http://mx-3.com/phpBB3/viewtopic.php?f=46&t=75217
92 RS with lowering springs, and body kit.
SpatialTerror
SpatialTerror
- Dragon1212
Pain in the Behind to get out of when your 5 ft 11 and you use the door to yank your self out of that hot thingred17 wrote:i need to look him up then, what about the universal kits on ebay, think they might work?
how can you not like this?
Worklog for the Blue One
Worklog for the KLZE
First Car, And My baby... $550 To buy and repair from Write-off... The radio and amp that was in it was worth more than that!!!.
Hunting For a Supra MKIV, but I'll never get one. Still Hunting.
Maliceday
I use to love the Lambo doors... Use to... Now, this is about how I feel...
To answer your question though, some kits are 'bolt on' some require cutting and welding. Most bolt on kits state that some modification may be required. So, unless you go to a site like http://www.verticaldoors.com/ and get a set that was made spacifically for the MX-3, then your probably going to have to do some work for proper results.
Nitrous is like a hot chick with a STD. You know you wanna hit it, but you are afraid of the consequences...
