turbo leaking oil from outlet?
Ok i have just installed a brand new 16g evo 3 turbo on my B6 and it is leaking oil from the outlet..what would be causing this? Are the seals done?? my car is blowing alot of white smoke when i drive it, but not when idling is this because of the oil in the outlet??
- XxantwawnxX
is the oilreturn facing down? Might need a ristrictor plate for the inlet. Is ur inlet -3?
- Josh
i would say the seals are done. i went threw several turbos that did the same thing. pull off your intake side and check your slop. in and out up and down. chances are there is slop in and out. the whit smoke is from the water inlet of the turbo, at idle it evaporates off. thats why no smoke at idle. unless you dont have the water inlet hooked up, then it could be worse. how is your oil pressure?
- XxantwawnxX
What company? it was not XSpower or SSautocrome by any chance?
