Green Cotton Air Filter
- TheBlackMoth
Hi, I recently bought this filter, but I don't really know how to it properly, its not as simple as the old K&N fitting.
I have searched the site and can't find any information on fitting this particular filter apart from the fact that you need to drill a hole in the filter for the pressure pipe, but I'm no mechanic so I want to make sure I get exact instructions before I mess up my car!
Basically I was wondering if anyone on the site has fitted this filter before? If so could you help me out a bit?
I've spent £70 on this and I really want to get it fitted, so any help much appreciated!!
Thanks!
Thanks!
Lookin Good
http://i36.photobucket.com/albums/e18/o ... 000493.jpg
1.8 V6, MODS: Richbrook Steering Wheel, Green Cotton Air Filter, 16" Wheels, Speakers, Sub+Amp
MODS Planned: White Dials
- MX3 GSR for dummies
Not sure of which filter your refering too but you shouldn't have to add any holes! Post a pic of the filter and we can probably guide you in the right direction
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
- TheBlackMoth
Thanks for the quick reply, here is what they say to do in the instructions:
http://www.greenfilters.com/index/GREFi ... artNo=P114
It just doesn't seem that clear to me though...
I was expecting to just undo a screw, take the old filter off and screw on the new one...I guess its not that simple!
Lookin Good
ME EITHER!!!TheBlackMoth wrote:It just doesn't seem that clear to me though...!
Try some other way and I'll check it out
- TheBlackMoth
hehe, sorry mate, I seemed to have pasted the link twice, here's a working link:
Lookin Good
mine was just a cone filter but fit very similar i'll post pics later
check my car domain
http://www.cardomain.com/ride/2144443
lakersfan1
my car kept cutting out when i disconnected it:
heres a pic .... excuse the engine bay i'm in the process of sorting it:
this is the part you need to take off your airbox and relocate. then all you do is just hook up the cone filter to the black tubing
away you go
check my car domain
I had the Cotton Green filter-kit before.
Easy to install, dont have to create ANY holes.
Just follow the instructions.
Basically you just remove the stock box, and put the new filter (with the elastic tube) onto the MAF, and tighten it down with the supplied band.
VERY easy
Might be a small hole on the bottom of the filter for the small "plug" wich the hose that previously went to the stock airbox should be connected too.
4 years since I used this, so I dont remember all that well
nope-mx3
VERY easy
nope-mx3
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
lakersfan1
If you disconnect it, yoiu have to route a piece of vacuum hose from the cylinder 6 intake runner vacuum port directly to the adjacent fuel pressure regulator on the fuel rail end. Then, it should run fine. I've taken it out of a few MX3 V6 with American and Japanese ECU's. All it does is helps with less customer complaints about a warm restart taking an extra crank or two.BADMX3 wrote:my car kept cutting out when i disconnected it:
this is the part you need to take off your airbox and relocate. then all you do is just hook up the cone filter to the black tubingaway you go
Do you have a pic of what you mean?lakersfan1 wrote:If you disconnect it, yoiu have to route a piece of vacuum hose from the cylinder 6 intake runner vacuum port directly to the adjacent fuel pressure regulator on the fuel rail end. Then, it should run fine. I've taken it out of a few MX3 V6 with American and Japanese ECU's. All it does is helps with less customer complaints about a warm restart taking an extra crank or two.BADMX3 wrote:my car kept cutting out when i disconnected it:
that would be really helpful
nope-mx3
I created my own CAI but had the same issue with that vac hose. You just hook the vac hose that sticks out 90 degrees from the sensor to the fuel pressure regulator and take the bottom vac line and attach it to the inlet near by on the IM. If you have to remove the cruise control vac line from either one of these...as I have seen on some cars, then just tie it in to the larger hose just after the TB with a T connector
- TheBlackMoth
Thanks for the help guys, great stuff
I have removed the old box etc and I now have the new filter fitted, but I still don't really understand what to do with the tube from the solenoid valve that used be connected to the air box...
Do I need to connect this to the air filter or something else?
Sorry if I'm being a bit dumb, i'm not the best mechanic in the world!
Thanks!
Oli
Thanks!
Oli
Lookin Good
Your not being dumb. First tell me where your vac hoses lead to that are attached to your fuel regulator which is attached to the fuel rail just to the side of the disty on your IM. Also then notice there is a vac hose on the IM beside that...where does it lead?
- TheBlackMoth
Cheers man, I'm not really sure what the fuel regulator looks like... I think I located the fuel rail on the IM though...what do the vacuum hoses look like and is the diameter about 1 inch? Do you have a picture of it?
Here is a picture of my engine at the moment:
Do I not have to connect the loose tube in my hand to anything?
Thanks a lot!
Thanks a lot!
Lookin Good
