guage lights out
ncraigh
guage lights out
Post by ncraigh »
my guage lights are out. The fuel, engine, brights, lights inside the guage still work. THe only thing that dont work are the green lights. I checked the fuse box and all are fine. I then took the whole front dash off to get at the lights. So i replaced two of the green lights with two new 194 lights. put it all back and nothing. same ones are still out.
Grants
BANNED Member
Post by Grants »
Probably the dimmer switch. You can bridge it out if your happy to not be able to dim them.
