Got my KLZE
IanL
Re: Got my KLZE
Post by IanL »
Originally posted by Alpha Male:
OK, I`ve apperently got a KLZE,im going to check it out this weekend.I have 3 questions
1.As the differance between the final gear ratio`s is not massive is it possible to run a KLZE on a K08 gearbox?
2.Is it possible to just re-map my K08 ECU rather than hunt around for ages for a KLZE ECU?
#1. Yes, I gather nearly all KLZE MX-3s retain the K8's gearbox
#2. I believe the knowledge to do this is confined to Mazda and Nippon Denso. There are re-mapped ECUs available in the US, but the reports of them are pretty poor. There is one chap who put up on a website that he thought he had identified the functions of most of the code, but that did not mean he had got it correct, not that he knew what values to change to.
<small>[ May 28, 2004, 10:59 AM: Message edited by: IanL ]</small>
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
