View unanswered posts | View active topics It is currently February 18 2020, 12:25 PM
Reply to topic  [ 8 posts ]
 How to measure signal for tachometer?
Post How to measure signal for tachometer?
Hello,
my tacho stop working (HEI without resistor) so I buy a used one and replace it. Both are same TAA77-A. Unfortunetely new tacho also don't work. Now I would like to measure the tacho signal from distributor and also from dash board connector to find out where is the problem.
How can I measure tacho signal?
Which conector on distrubutor TOT57171 gives tacho signal?
Which pin on dash connector should give tacho signal?
I have 1997, V6 with LPG.
Kind regards from Slovenia
January 13 2015, 1:04 PM
Post Re: How to measure signal for tachometer?
Check out the online manual wiring diagram.
http://www.mx-3.com/manuals/showimg.php ... /Z-058.gif
If I'm reading this right, there should be a yellow wire with a blue stripe going from your disty to the gauge cluster. However, I am not an electrician and am prone to being wrong :lol:
On the other side, I was under the impression these cars stopped being made in 96..? and you have LPG as in Liquid Propane Gas? That's an awesome conversion!! Wires should still be the same tho, hopefully. GOOD LUCK!!
I HATE mechanic shops and LOVE junkyards!!
January 14 2015, 2:41 AM
Profile YIM
This post is found in the FAQ section. I'm ass-uming yours is a V6? viewtopic.php?f=23&t=69006 On the 96/97 two of the 3 wires on the 3 wire disty plug are reversed as you can see. If you don't use the resistor the tach will not work.
January 14 2015, 5:46 PM
So 2C pin on cluster connector should give signal for tacho (it cames from distributor 3pin C).
How this signal can be measured? With Voltmeter? If yes, which voltage is at cca 1000rpm?
@MX_Sid
Mazda produce MX-3 up to 1998. Yes I have LPG (liquid petroleum gas).
@Daninski
Yes I have V6 (I wrote it). I find your link already before but this is wiring for TOT57271. I assume it's same as for my TOT57171.
P.S. I don't know how to paste the picture into post.
January 15 2015, 2:45 PM
Hello,
Can anybody tell me how to measure tacho signal?
January 18 2015, 7:36 AM
Disties are not the same. No cam sensor in yours and like I said the 3 wire plug is wired differently. Can't remember the wire order on the cap.
January 18 2015, 5:59 PM
Hi Daninski,
I'll find it, what would like to know is how can I measure tach signal?
January 19 2015, 1:03 PM
You need a lap scope. I don't have a V6 car with a distributor other wise I would take a picture and show you.
January 22 2015, 11:56 AM
