View unanswered posts | View active topics It is currently April 04 2020, 11:21 PM
Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Overheated on highway ==> Thermostat?
Post Re: Overheated on highway ==> Thermostat?
SuperK wrote:
fill it up by the filler cap next to #8 on the second link.
The filler cap is the cap on the passenger side, the radiator cap is on the drivers side.
Here are some directions from wytbishop that has a pretty clear explanation of some steps:
Quote:
With the engine running, but COLD, remove the top filler cap on the passenger's side of the engine and fill right to the top. Now leave it off and carefully remove the rad cap. This will allow any air in the radiator to escape. Replace the rad cap when it gets to the top and then fill the engine right to the top again. Make sure the overflow res is filled to the bottom line and your cooling system will be totally full
Thanks man I really appreciate your help. So its okay to run the car while I'm this low on coolant? I suppose it will be fairly cold long enough to fill it.
93 Blaze Red GS
May 19 2014, 12:01 PM
Followed wytbishops steps and everything is looking good. Thanks everyone again.
93 Blaze Red GS
May 20 2014, 9:12 PM
Or you could have a blown head gasket. Just sayin,,, :shrug:
May 20 2014, 9:28 PM
Yeah, I mean I lost all my coolant for a reason so I'm keeping an eye on the level and for leaks.
93 Blaze Red GS
May 20 2014, 9:29 PM
Coolant just doesn't disappear. Maybe it's been slowly leaking out and you just didn't notice.
May 23 2014, 7:41 AM
I'm with dan, have you checked the tailpipe for white smoke and a smell of caramel?
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
May 24 2014, 3:02 AM
Ended up being the water pump leaking :P
93 Blaze Red GS
August 02 2014, 1:00 AM
Users browsing this forum: No registered users and 3 guests
