View unanswered posts | View active topics It is currently January 18 2020, 2:06 AM
Reply to topic  [ 3 posts ]
 [Question] Crossmember Suspension Mx-3 B6 Soch 1993
Post [Question] Crossmember Suspension Mx-3 B6 Soch 1993
Hello everyone,
I had an accident and was hit front, with the love I have to MX3, decided to repair damage, identified was determined that crossmember Suspension and Shifter Linkage should be replaced.
Reviewing parts supported the suspension crossmember note that is compatible with the 90-94 1.8L Mazda Protege, in the junkyards of my country (Guatemala) only found MX3 1.8L V6 and it is not the same crossmember.
My question:
1 -. The Mazda Protege 90-94 crossmember is compatible without any modification?
2 -. The Shifter Linkage Protege/323 90-94 Mazda is compatible without any modification?
tks.
Best Regards
March 14 2014, 5:56 PM
Profile YIM WWW
Post Re: [Question] Crossmember Suspension Mx-3 B6 Soch 1993
Anybody?
March 17 2014, 3:20 PM
Profile YIM WWW
the crossmember itself should be compatible.
I would use the 1.8l V6 crossmember. it will be a bit of an upgrade from what you have if you get the crossmember and the crossmember reinforcement.
The only difference is the 1.8l V6 MX-3 has four threaded holes for the reinforcement bar to bolt on to.
It also seems the protege crossmember is the same as yours.
The shift linkage for the 1.8l MX-3 is EA0346060, seems GS specific.
The shift linkage for the 1.6l is B45546060
The "compatible" list shows:
Mazda 323 1990, 1991, 1992, 1993, 1994
Mazda 323 S 1995
Mazda MX-3 1992, 1993, 1994, 1995, 1996
Mazda PROTEGE 1990, 1991, 1992, 1993, 1994
Mazda PROTEGE S 1995
Hope this helps.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
March 18 2014, 1:34 PM
