View unanswered posts | View active topics It is currently April 07 2020, 10:54 PM
Reply to topic  [ 9 posts ]
 turbo feed kit
Post turbo feed kit
Hey guys I am upgrading my turbo got a 57 trim t3/t4 and I need the right feed line kit and need a link to everything I need so I don't blow the new turbo up. If anyone could help me out that would be great thanks.
June 11 2013, 9:34 PM
Post Re: turbo feed kit
Like this easy Ebay search for a t3/t4 turbo feed kit found?
http://www.ebay.com/itm/T3-T4-T3-T4-T70-T61-T04E-T60-TURBO-OIL-INLET-FEED-LINE-1-8-NPT-36-INCH-FREE-SHIP-/200933349171?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec88f9733&vxp=mtr
June 12 2013, 12:47 PM
Ok thanks but was talking about everything even the bolt that goes into are block.
June 13 2013, 10:46 PM
What engine do you have?
And are the feed lines from ebay good quality? I've got a gt28 that I need all new fittings for, might try to find a complete set of feed lines and banjo bolts and stuff.
Daninski wrote:
This is my MX3. There are many like it, but this one is mine. My MX3 is my best friend. It is my life. I must master it as I master my life. My MX3, without me, is useless. Without my MX3, I am useless. I must fire up my MX3 true. I must drive straighter than any Honda driver who is trying to own me. I must own him before he owns me.
June 13 2013, 11:00 PM
1.8 dohc bp motor
June 14 2013, 3:31 PM
All you do is tap into the back of the block where the oil pressure sensor is. So a T fitting with two male sides and one female. Then buy like 18'' long SS braided line. and done.
Or find BPT hard lines from someone. Use whatever the turbo manufacture recommends.
June 14 2013, 6:17 PM
Y would i tap into the back when the oil is up front on are motors. I am asking for the right stuff to use the line up front and that gives my urbo the right amount of oil.
June 14 2013, 11:11 PM
1/8 bspt thread for the ports on the head. Not sure how good the supply up top is.
View Worklog
June 15 2013, 4:50 AM
Aww see now we are getting somewhere.... You want OE BPT hard lines!? YES?
Your best bet is to find them in club protege used. I am pretty sure I have a set laying around. AND FYI there is just as much oil pressure on the back as there is the front fitting. And it is not doing it "wrong" by tapping the rear, most people do. It is easy, and away from the exhaust unlike the OE port on the front. The OE hardware will only fit a IHI VJ14, VJ11, VJ20 or VJ26. It could be adapted to fit others. I have run a VF10 and a VF12 as well. I understand what you are saying about doing it "right" but it is not as critical as I think, you, think it is.
June 18 2013, 12:26 PM
Users browsing this forum: No registered users and 3 guests
