View unanswered posts | View active topics It is currently August 04 2020, 4:20 AM
Reply to topic  [ 2 posts ]
 Need info: how to get MAP with ITBs!
Post Need info: how to get MAP with ITBs!
I have done a bit of searching, and just need to talk to someone who has successfully run ITBs on either engine type.
As far as I can tell, I can run vacuum lines from each runner, into a small plenum, and get a smooth signal from that. Is this correct? If so, can I run the FPR signal from it, too?
I plan to make my own throttle bodies, so I'll have to make all of these components.
November 17 2012, 8:23 PM
Post Re: Need info: how to get MAP with ITBs!
You have the right idea... You could run the FPR off it... all though the FPR doesn`t need a clean signal to work properly...
November 17 2012, 8:41 PM
