View unanswered posts | View active topics It is currently June 18 2013, 6:39 PM
Reply to topic  [ 8 posts ]
 K8 heads on KL?
Post K8 heads on KL?
Serious question, has anyone tried or know if its feasible with some machining to fit a K8 head to a KL with KL cams? If anyone knows of how/if its been done please add some info/links thanks!
June 03 2012, 1:28 AM
Post Re: K8 heads on KL?
Hmmm...there's a good chance it would fit. You need to get a K8 head and compare it to a KL head gasket to see if the ports line up. There could be differences in the location of oil galleries and/or coolant paths.
I'm curious what your goal is in doing this.
93' GS SE, the love of my life...now with ZE Power!!!
June 03 2012, 2:44 AM
Different bore.... if KL piston rises above deck surface, it will not work.
Black '93 BP RS - RIP
Green GS - Sold
Red GS - K8-ATX -> MTX-KLDE - Winter DD. Well behaved.
White GS - Rusty. Parts.
____ GS/Miata - to be built and kept as a summer/sunday car!
I'm a JYA. Junk Yard Addict.
June 03 2012, 8:21 AM
Actually Ryan any chance you have both a KL and a K8 head sitting around to compare with some photos? I know the mating surface at the pistons will be different but Im wondering if machining can clear that up.
June 03 2012, 11:23 AM
Online
I have k8 heads lying about and KL head gaskets. I'll take some pics tomorrow if I get a minute.
Autozam AZ-3 1.5 B5ZE - Sooty 2.0 - Project eco-boost
View Worklog
June 03 2012, 6:28 PM
My guess as to his goal would be radical port shape modification... Smaller ports means more material to be removed, more material to remove means more potential for change. I like the idea myself!
92 GS - Built by me, for me. I do things a little differently...
93 GS
93 GS(KL) - Sold
"More than you can afford, pal. KLZE."
Taking a break from the whole car thing for a while.
June 03 2012, 8:45 PM
Thanks Ild appreciate it!
June 03 2012, 11:03 PM
Online
http://marcharrington.com/mx3/k8/k8headKLgasket.jpg
http://marcharrington.com/mx3/k8/k8head.jpg
http://marcharrington.com/mx3/k8/gasketCompare.jpg
http://marcharrington.com/mx3/k8/k8valves.jpg
All fluid holes appear to line up on initial comparison. Cute little exhaust valves on the k8 :lol: Least aligning part is the cylinder bore itself. Though it should seal fine... To me looks like the same gasket except the k8 gasket cylinder bore is lesser diameter. Both are genuine mazda gaskets AFAIK.
View Worklog
June 04 2012, 6:09 AM
