View unanswered posts | View active topics It is currently July 09 2020, 12:39 AM
This topic is locked, you cannot edit posts or make further replies.  [ 38 posts ]  Go to page 1, 2, 3  Next
 Weight of the complete A/C system?
Post Weight of the complete A/C system?
I've been unable to find it via search, although I found some great work logs.
I'm basically wondering if anyone yanked their A/C and weighed everything, and if so, I seriously hope you wrote the weight down.
Thanks!
'12 Challenger R/T Plus w/ STP - 3.92 w/ Limited Slip, Shorty headers, SkipShift delete, Clutch Delay Valve delete, Hurst STS, RAM Clutch Adjuster, StopTech 6 Piston Brakes, Sticky Nittos, Tuned
'92 GS 5 spd - Straightneck KL, 67mm TB, MegaSquirt, Coilpacks, 5 lugs, Speed6 brakes, FD wheels, wiretuck, progressive coilovers, shorty headers w/ custom collector, AEM WB, 2.5" straight, Borla XS
June 22 2011, 3:46 AM
Post Re: Weight of the complete A/C system?
Are you planning to get rid of your A/C? :shock:
Either way, it's really not the weight savings that's important, but the hp savings on the engine. I don't know exactly how many horses the mx-3 A/C takes, but A/C's in general tend to take a lot of it.
Diogenes of Sinope.
June 22 2011, 9:33 AM
I have 2 complete A/C systems in the garage... if I get around to it I could weigh everything this weekend. I'm guessing close to 20-25 lbs. since the compressor and condenser have some weight to them.
June 22 2011, 11:11 PM
The compressor alone is AT LEAST that much, I have one laying around, it's a heavy mofo - you could work out with it. I would give it in the 30-40lbs range. Then consider the refrigerant, lines, condenser, condenser fan, receiver drier, and interior cooling unit plus all the relays. I'd guess the whole thing is at least 100lbs.
June 22 2011, 11:30 PM
I'm not planning to at this point, but I'm definitely considering it... Especially if it weighs in at 100 pounds LOL. It'd be beyond consideration if it's quite that high...
I don't use A/C, even when I have it. I live in Oregon, and on days when I would even consider using it... I'm not driving a car haha, I'm on a boat or on the river swimming.
Mark, I'd be VERY grateful for an accurate weigh on that! Do you happen to have the relays and wiring as well, as nightshade pointed out? Also, any chance you could get the weight of the refrigerant as well? I doubt you kept it after you yanked the A/C... but I know nothing about A/C in general. :shrug: :oops:
June 24 2011, 2:25 AM
The refrigerant is the easy part: less than 2 Lbs (and a few ounces of oil).
I wouldn't get rid of the system. You never know what's gonna happen in the future. Just putting a new, shorter belt in (avoiding the A/C compressor) will give you the extra HP of not having to spin it for nothing, and you will be able to reverse it easily, should you change your mind in the future.
Diogenes of Sinope.
June 24 2011, 9:48 AM
Well think of it this way. Me and JWMX3 both have 94 GSes with no AC and removed rear seats. A GS is supposed to weigh in the high 2500lbs but ours are at 2400 something lbs. I highly doubt just removing the rear seats is enough to drop it that much.
June 24 2011, 10:18 PM
I'm planning to "de-belt" the A/C already, this is just a tentative idea for a 2nd car coming in the future. A track only car, I'd like to shave 500 pounds out, and this sounds like at least 75-85 pounds(leaving margin for error) that's relatively free, especially for a track only car.
June 25 2011, 1:20 AM
For a track only car, definitely. Getting rid of the A/C is a must. I'd also recommend getting rid of the power steering.
Diogenes of Sinope.
June 25 2011, 12:45 PM
It's on the list too, 323 Manual rack makes it stupid NOT to do it :D
June 25 2011, 2:46 PM
Yup.
What kind of racing are you planning to do?
Diogenes of Sinope.
June 25 2011, 8:27 PM
I'm not sure yet, it really depends... If I take the time to make a track only car, I'm thinking FE3T and drag...
June 26 2011, 4:35 AM
Hmmm...straight line? I thought you could drive...;)
Diogenes of Sinope.
June 26 2011, 3:22 PM
This page will give you an idea the components that make up the A/C system (I believe 92 and 95 are the same and 4 cyl has 2 fewer relays than the v6):
http://www.mx-3.com/manuals/showimg.php ... -G-049.gif
Note these weights are not precise... I was using a bathroom scale (LOL) but it will give you a good idea!
A/C Compressor (including bracket and bolts): 17 lbs
Condenser Fan: 4 lbs
Condenser: 4 lbs
Receiver Drier: 1 lb
Refrigerant Lines/Pressure Switch/Relays: 3 lbs?
Cooling Unit (inside the car): 9 lbs
Total estimated weight +/- 40 lbs
So as I was going through this, it dawned on me that the second fan is for the A/C only? Is this correct? It doesn't run at all in conjuction with the other fan?? :o
LOL at nightshade's estimate - you should probably start lifting weights if you think the compressor is heavy... :wink:
And Inodoro why do you recommend getting rid of power steering?
June 26 2011, 4:52 PM
I'm not 100% sure, but, initially, yeah, it's just for the A/C.
You save some weight, but, most importantly, you free a few hp.
I've been involved in racing for a few years in the past. For any kind of serious racing, the motto is: "if it doesn't make you faster, it makes you slower".
Diogenes of Sinope.
June 26 2011, 5:05 PM
Users browsing this forum: Bing [Bot] and 0 guests
