View unanswered posts | View active topics It is currently August 09 2020, 7:14 PM
Reply to topic  [ 165 posts ]  Go to page 1, 2, 3, 4, 5 ... 11  Next
 [FS]SuperK's Parts! OEM Full-Length Sides, SE Interior 12/21
Post [FS]SuperK's Parts! OEM Full-Length Sides, SE Interior 12/21
SuperK's Parts List!
All parts First Come, First Serve.
May accept monthly payments. Ask with details of payment arrangements that can work for you
If you are interested in any pending items, please wait until I have them available.
Items are "Buy It Now" Style. I will not "hold" items if I have another buyer ready.
Updated 12/21/14
______________________________________________________________________________
Generic For Sale:
1x Set Full-Length OEM sides, red - $800
1x Erebuni rear bumper, new, primer - $250
1x Set of Front SE leather seats - $300
1x Set of Rear SE leather Seats (upper/lower bench) - $300
1x 92-93 Window Switch, no "auto" function - $70
1x Foglight set with brackets - $50
1x passenger power window regulator - $30
1x passenger door shell - $50
1x E-brake cables - $30
2x Wiper Cowls - $30/each
2x OEM Plastic Oil Caps -$5/each
2x Center Console Center Cubby Holes - $5/each
1x Manual window conversion - $150 (includes door cards, regulators and all)
2x Front mudguards (white or green) - $15/each set
1x JDM Front Lip - $200
1x Interior blower fan/motor - $10
1x 93 GS spindle set, new wheel bearing pressed in, like new ball joints - $100
1x Clutch Master Cylinder - $10 (Any model)
1x Broken Window Switch (Passenger button broken, drivers works) - $5
GS Parts:
1x Complete AC system including lines, wiring, relays, compressor and evap assembly (minus condenser) - $150
1x GS Heater Coil assembly, mint condition - $80
1x GS Clutch pedal assembly (for manual conversion) incl. master cylinder hard line and stainless steel clutch line. - $30
1x GS Steering Rack - $50
1x GS Rear Subframe w/loaded spindles (Calipers/pads/rotors), front and rear proportioning valve - $150
1x Front Crossmember and Sway Bar - $80
1x Crossmember Reinforcement (GS Subframe) - $30
1x K8 Throttle Body with TPS/IAC/spacer - $30.00
KL Parts:
2x KL/K8 Front Valve Cover w/Breather hole -$10/each
1x KL/K8 Front Valve Cover w/o Breather hole - $10
1x KL/K8 Front Transmission Mount, cracked - $5
1x KLL2 ECU (from a 96+ Xedos9) - $40
2x Harmonic Balancer - $20
1x KL water pump (93 version) - $10
2x Set DE retainers (12) and Keepers (24). OEM New - $150/set
5x Connecting rods - $5/each
2x Set DE Springs (12) - 50/each
B6DE Parts:
16x B6 DOHC HLA's, New - $2/each
1x B6DE Clutch Slave Cylinder - $10
1x B6DE Clutch Master Cylinder - $10 (Any model)
1x B6DE Fuel Rail w/FPR - $10
1x B6DE Brake Booster - $10
1x B6DE Power Steering Pump - $15
1x Tested AC Compressor, R134A, B6 (Rebuilt eBay Special!)- $40
Pending
Local Pickup:
Passenger side door shell - $40
GS Hatch w/wiper - $50
Rear subframe (for RS to GS disk brake conversion) - $100
Sold:
1x Driver side fender (red) - $30
1x Driver side door shell - $40
1x GS Black Carpet, complete - $50
1x Center Console Center Cubby Holes - $5/each
1x Set ZE Pistons, cleaned - $150
1x Hood latch cable - $10
1x '93 Front dash, mint - $100
2x B6DE MAF - $10/each
1x Broken Window Switches (Passenger button broken, drivers works) - $5/each
1x Set Chrome Interior Handles - $25
1x GS Front Lip Set - Cracked - $30
1x UK Window switch excellent condition - $60
1x OEM MX-3 shifter - $5
1x OEM MSP5 shifter - $50
1x Set AZ3 Stainless sides - $200
1x Set Eunos Stainless sides - $200
1x Starter - $20
1x Set ZE heads, bare. Great condition. - $80
1x OEM USDM Bumper (Teal) - $20
1x Green damaged Mazdaseed replica front bumper $150 SOLD
1x Set K8 Injectors, in fuel rails, tested - $20.00
4x B6DE Injectors, professionally rebuilt/cleaned/flow tested 1 year ago - $10.00/ea
3x Euro Window Switch - $50
2x Set of clear USDM Headlights - $30
1x Chilton's 94-98 MX3 Repair Book - $10/Each
1x Wytbishop's Endlinks - $150
1x Genie B6 Headers - $75
1x B6DE Water Pump, 1 Year Old - $15.00
1x Set USDM clear plastic headlights - $20
1x Sets KL Injectors, tested - $30
1x Rear Crossbar (Bolts to the bottom seatbelt bolts) - $50
1x Set of B6 Miata Stage 2 Cams - $250
1x Set of JDM Headlights - $100
6x EDM Bumper Cover - $150
5x Set Rear Mudguards - $40
1x B6-DE MTX Transmission - $75
1x Slim Visors by FowlJesse - $100
1x Set JDM Full Length Sides - $400
1x JDM Front Lip -$200 - Curtklze
1x Set of front SE Leathers -$200
1x Set of Euro Signals - $30
4x Front Lip, Complete - $50
1x Flowmaster 60 Series Muffler, includes Chrome insulated single tip - $50
5x Euro Mini Side Skirts - $150
2x Black Front Lips, Complete (needing epoxy, cracked on the passenger side. 2 pairs) - $25/each
4x Chrome Interior Handle Set, Great Condition - $50
3x OEM Euro Foglight Set - $30
2x OBD1 '93 K8 ECU's, Chippable - $30.00
3x Front Tow Hook - $20
1x B6 DOHC Distributor - $50
2x Fenders - $60
1x K8 AC Compressor - $30
1x Vacuum Solenoid FPR/VRIS
1x Stock shift boot
1x Carbon fiber gauge sticker
1x 3rd Brake Light
1x KL/K8 rear valve cover
1x KL47 Intake Manifold
1x Roof rain rails - $15
1x Drivers side power window regulator - $60
1x Broken drivers side window switch - $5
1x B6DE MAF (B6BF)
1x sunroof metal deflector and links - $30
2x GS Spoilers (Black/Teal) - $20/each
1x Euro center vents - $20
Payment:
[size=50]
Preferred: Check/Money Order. PM For Address
Not Preferred: Paypal. Superk86@gmail.com. Add appropriate % for fees.
Adding:
Sold:
1x Euro mini sides, red - $75
1x Euro dash vents (closable, 3 pieces) - $50
1x Glass LHD headlights. w/motor, missing 1 tab. Glass has been removed and interior painted black. - $200
1x Glass LHD headlights, casing damaged, good lenses. - $100
1x OEM MX-3 floor mat set - $50
1x Sunroof Assembly - $60
1x window switch, no buttons just PCB - $5
1x Set Hatch Struts - $20
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
November 06 2009, 3:48 PM
Post Re: SuperK's Random Parts Pile. Sideskirts, Mudguards, Fog,
Blank Post
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
Post Re: SuperK's Random Parts Pile. Sideskirts, Mudguards, Fog, ect!
pm'd
November 06 2009, 5:11 PM
Post Re: SuperK's Random Parts. Sideskirts, Lips, Muds, Fogs, Etc!
pm.d
November 07 2009, 10:40 AM
superk i sent u my number txt me or cal about meeting.
November 08 2009, 1:46 AM
Hi SuperK.Please foglights pics...
MX-3 B6ZE Noble Green
November 09 2009, 11:28 PM
Post Re: [FS]SuperK's Random Parts. Sideskirts, Lips, Muds, Fogs, Etc
hey, interested on the sides....
i'll PM you with some offers and see where we go from there, ok?
'91 MX-5 with plenty of mods, '94 DOHC MX-3__HP Design muffler, glasspack, custom intake (superk's idea), KYB GR-2 shocks, projector headlights, GS front end, Rear Disc brake conversion, swaybar and tie bar, and lip spoiler, JDM mazdaspeed full-length side skirts,
November 13 2009, 12:42 AM
Profile YIM
Still up for grabs. Will post more pics when I get the time.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
November 30 2009, 11:13 AM
pm'ed u earlier today!
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
November 30 2009, 6:51 PM
Profile YIM
Post Re: [FS]SuperK's Random Parts. Euro Sides, Lips, Dist, Fogs, Etc
Updated availability today.
Just to let you know the UK version of the master window switch works just fine. The only difference is the order is reversed. left button is passenger, right is drivers side. But I've never heard of these switches breaking and aren't in high demand in the UK. I am using one in my RS and it works great. Seems the Auto functionality has a durability measure where you raise it too high, instead of breaking it, it sort of "locks" (even though I swear I break it every time I use it, haha! It works great!)
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
January 29 2010, 11:11 PM
I neeeeed a Euro bumper support. C'mon...I thought you were the euro bumper guy...If you still have a nice lip in the spring I will take it for molding purposes.
January 30 2010, 3:36 AM
Post Re: [FS]SuperK's Parts List! Updated Feb 16!
Updated with some puter bundle and pictures
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
February 16 2010, 11:40 AM
hey i am interested in the computer bundle. can you email me some pictures of the case, unclesluggo@shaw.ca thanks.
1993 White gs klze.
February 16 2010, 12:10 PM
No case just parts. There is a pic of the parts above
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
February 16 2010, 3:16 PM
interested in the yellow fogs if still available. Pm me
February 17 2010, 12:34 AM
