[FS] SRD Reproduction Parts - Crossmember, Tie Bar & E-Brake
Author |
Message |
Joined: May 25 2002, 2:01 AM Posts: 11212 Location: CFB Val-Cartier, Quebec, Canada
Prices: Reproduction SRD E-Brake Handle : C$65 (Mx-3, 323, Protege, 626 and Mx-6)* Reproduction SRD Tie Bar : C$100 (MX-3 4cyl and V6) Reproduction SRD Crossmember : C$200 (Mx-3 V6 only) *batch limited run of approx 30 units because on how the material is ordered. Subsequent batches can be done if there's enough demandAs I'm sure many know that SRD no longer makes any of their products. (:(). It took me several months just to find a used one, and even then i had to make a nice offer since they were on a car, but no matter, I got them. I know that a few people mentioned that they're interested in those parts, and after the difficulty I had to even find used ones, so I hoped that I could get them reproduced. Bochek makes aluminum parts, but they're too big for his machine,but I have a friend in one of my car club that I asked him if he could and he's very confident he can (he owes me since i help him with his air ride system ). I dropped off my parts to him thursday and I told him to make at least one set to see how it comes out.
I *think* the original SRD parts sold for around $150 for the crossmember and $80 for the tie bar. I don't have a price on making them yet, but i'm using those prices are a guideline to see if they're worth making. I have no idea on how expensive it is to get parts out of aluminum machined, but hopefully they're not much more compared to SRD's, if anything.
And yes I'l contact Jeff about the group buy stuff, I just want to get an interest and post the details on getting these done, if it's feasable.
Quote: SRD Front Crossmember: -"V6 owners: upgrade your 4.5lbs OEM Stamped steel Crossmember with a stronger, stiffer and 1.5lbs lighter Aluminium billet unit. This crossmember installs in minutes with basic tools. Helps to maintain the front suspension's geometry under hard cornering, provides faster steering response and significatly stiffens the chassis. CNC-machined from 6061T6 Aluminium, comes unpolished
Function: the crossmember (sometimes called transverse member) joins the two chassis pickup points of the front suspension's control arms. Under heavy cornering, tremendous forces are applied to the chassis and without proper bracing will flex and generate poor steering response. V6 MX-3s are fitted with a "C" shaped stamped steel crossmember economical to mass produce. OEM brace provides a relatively high degree of bracing but because of the "C" shape some deformation is allowed. Furthermore, torsional resistance is quite poor: you can actually twist the part with your hands. Here comes the SRD crossmember: 150% stronger longitudinally and 275% stiffer torsionnally. As a bonus part is 1.5lbs lighter. Don't let your car twist in the twisties!"
Quote: SRD Rear Tie Bar: "V6 owners: upgrade your OEM rear lower tiebar with this work of art!
4 cylinder owners: your car is missing an important part especially if you have aftermarket wheels and/or lowered suspension! This tie bar installs in minute with basic tools and helps to maintain the rear suspension's geometry under hard cornering.
CNC-machined from 6061T6 Aluminium with adjustable rod-ends for easy fitment."
_________________ 1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
July 12 2008, 12:38 PM |
mitmaks
Joined: September 10 2001, 2:01 AM Posts: 8704 Location: Spokane, WA
 Re: [GI] Aluminum Crossmember & Rear Tie Bar - SRD Reproduction
i already have lower tie bar but interested in crossmember.
_________________ Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE '95 Cobra SVT #2722 '68 Charger R/T 440 http://www.cardomain.com/id/mitmaks
July 12 2008, 12:46 PM |
Damn that was quick..
You still ahve that? I came across some threads about you trying to sell it, I didn't realise no one actually bought it.
July 12 2008, 12:48 PM |
mitmaks
i have it installed on my car, bought it on ebay from some loser.
July 12 2008, 1:04 PM |
Leedeth
Joined: July 12 2007, 2:18 AM Posts: 82 Location: Victoria, BC, Canada
Can that crossmember be mounted on the RS?
_________________ 92 MX-3 RS (B6-ME, MTX) - front/rear strut bars
July 12 2008, 1:28 PM |
fowljesse
Joined: March 17 2006, 3:59 PM Posts: 5676 Location: portland, OR
I am interested. Would they be using 6061T6? I've been thinking about finding a way to make myself some.
_________________ '93 GS - P&P DE w/ ZE exh. cams/ pistns, KLG4 IM, 65mm TB, MSnS, Phenos, K&N RAI, UDP, Grnd wires, rear batt, filld MM, torq strt, TWM short shftr, Exedy, Lng tube hdrs 2.5" Side exhaust, H&R sprngs, Poly bushngs, strutbars, Alum. crss mmber&tiebar, 22mm swybar, solid links, Direzzas, leather int, Alpine 9805 stereo & alrm, keyless entry, 10 Boston Accoustics spkrs, Prjectrs, Blaster2, CF hood, FG hatch, Lexan
July 12 2008, 1:42 PM |
RS_OBD'oh_2
Joined: April 09 2007, 1:26 PM Posts: 2400 Location: Calgary, AB
I need the rear lower tie bar.
July 12 2008, 2:02 PM |
Ryan
Joined: April 07 2008, 1:06 PM Posts: 7198 Location: Manitoba
Leedeth wrote: Can that crossmember be mounted on the RS? Yessir. But something in my brains says that some models you may need to drill and tap? It might have not even been for the MX though,maybe a protege? escort?.... I can't organize in my brain well. I just have everything in a mental pile. But yes, they fit on an RS.
_________________ Now with Moderator power!
Black '93 BP RS - wrecked, parted, scrapped. Green GS - Sold. Black GS - Summer DD/Race car - Fancy KLZE Red GS - K8-ATX -> MTX-KLDE - Frakencar. Scrapped White GS - Rusty. Parts. Scrapped 1997 BMW M3 - my summer baby 2002 BMW 325Xi - sold 2003 Forester Xti - EJ20K swapped. Feedback
July 12 2008, 11:00 PM |
Ryan wrote: Leedeth wrote: Can that crossmember be mounted on the RS? Yessir. But something in my brains says that some models you may need to drill and tap? It might have not even been for the MX though,maybe a protege? escort?.... I can't organize in my brain well. I just have everything in a mental pile. But yes, they fit on an RS. I'm not sure to be honest. As far as I've researched the answer is No. Quote from SRD back in 2003 Quote: 4 cylinder owners: your car is missing another important part especially if you have aftermarket wheels and/or lowered suspension! We are currently looking in ways to easily install this brace with minimal modifications to the RS' chassis. Stay tuned!< I've never seen this on their or Corksport's website so i guess he couldn't get it to work? I don't have an RS so I don't know. If I had an RS easilly acceesable to work with. It would be nice to find out on how to make it work, or even what it takes to modify it so it can, if possible. It is being blueprinted from scratch after all, but I can't find any information that even a stock GS crossmember was fitted on an RS fowljesse wrote: Would they be using 6061T6? First thing I looked into. I thought it was some fancy high-grade stuff but apparently that's just a standard alunimum, nothing fancy. So yes, it would be made in the exact same stuff.
July 13 2008, 10:55 PM |
mitmaks
i know that stock GS lower tie bar bolts onto RS so SRD should have no problem bolting onto RS either. If someone can get me pic of rear suspension of RS from behind and some measurements i could measure to be sure.
July 13 2008, 11:55 PM |
fowljesse
Yeah, it's not Easton, or anything, but there is lesser quality than 6061T6 that would fatigue faster.
July 14 2008, 12:00 AM |
fowljesse wrote: Yeah, it's not Easton, or anything, but there is lesser quality than 6061T6 that would fatigue faster. I'm going to get him to use at least 6061T6 since that's what is tried and tested. This isn't some cheap-knock-off money making scheme, nor some fancy item to dress up the Mx-3, this is to bring back a performance product that is no longer available and I intend on making them as 100% accurate to the SRD products. mitmaks wrote: i know that stock GS lower tie bar bolts onto RS so SRD should have no problem bolting onto RS either. If someone can get me pic of rear suspension of RS from behind and some measurements i could measure to be sure. Yes, the rear tie bar was advertised to work on an RS, it's the front crossmember that doesn't seem to work.
July 14 2008, 7:08 PM |
Leedeth
July 14 2008, 11:45 PM |
fowljesse
I'm totally in. In fact, if this doesn't make it tp production, I'd be interested in seeing what a 1-off set would cost.
July 15 2008, 1:43 AM |
rekognize
Joined: September 02 2006, 10:58 AM Posts: 809 Location: Toronto, ON
I'm down for a rear tie bar
_________________ Check out my Worklog View my Feedback
July 15 2008, 11:59 AM |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum
