View unanswered posts | View active topics It is currently July 07 2020, 10:53 AM
Reply to topic  [ 10 posts ]
 Hello from Michigan!
Post Hello from Michigan!
I'm Allie, and I'm from Michigan's lovely UP. I just bought my MX-3 yesterday.
She's a 1992 GS and she is quite the switch from my lifted Jeep Cherokee! That was the point of buying the Mazda, actually. I like my Jeep, but dang I'm tired having to save up for months in order to drive downstate to visit family. I snagged her for $1500 and the guy met me at the bridge rather than me having to haul all the way to, like, Muskegon. So anyway, I thought I would join up so I could start figuring out what things I need to do to get her running correctly, as there are some small issues here and there.
Photos. Everything is as the previous owner had it. I've only had her a day!
October 20 2013, 1:20 PM
Post Re: Hello from Michigan!
Welcome to mx-3.com. Looks like good little project. It should clean up nicely. I'd pressure wash engine to get rid of all that dirt/gunk. Looks like valve cover gaskets are leaking so replacing those would be good idea.
October 20 2013, 1:56 PM
Profile ICQ YIM WWW
Hey welcome new member. Yeah its safe to rip that tattered sound deadening or flame blanket thing from under the hood. Its not a necessity and you engine bay will thank you later
October 20 2013, 4:46 PM
Profile YIM
Thanks for the tip, mitmaks :)
I'll hunt those down and add them to the "things to do" list. It's growing by the second, it seems :P
Right now, I'm working on getting the heat to work. Seems like the thermostat is stuck open, so my engine has been running really cold, and most importantly, it's October in the UP and my hands are freezing.
Also, I've got to do something with that shifter. It's all over the place (like really loose feeling) and it makes it extremely hard to shift properly. I'm thinking about investing in a short shifter, as well, because that bad boy is ridiculously long!
I learned to drive a stick shift on my SO's modded out vehicle, so driving a "stock" 5 speed is a learning experience in itself! I think after we hammer out the small problems it'll be much more fun to drive. And then dealing with the power steering, as well. It doesn't work, but it actually seems like it's actively working against me! I've been doing some searching on the forums for different ideas on these issues (which has been extremely helpful by the way) and appreciate that you all seem to be patient and helpful.
Also, just wanted to thank you guys for posting the repair manual! It was an excellent discovery before I discovered a copy of it in my trunk.
October 20 2013, 5:35 PM
Hey hey Michigan owner here!!!
Woot where u live at?
Mazda3 2012 - my NEW DD :mrgreen:
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold :(
October 21 2013, 9:41 AM
Heya,
So the shifter is a bit of a pain. What you'll have to do is remove the shifter linkage from underneath the car.
You'll unbolt it from where the linkage attaches to the bottom of the shifter
then unbolt it from where it attaches to the transmission
There are three pivot points.
Two of the pivot points (the shifter end and the transmission end) have removable bolts, you have to remove them and install new shifter bushings.
The third pivot point is NON REMOVABLE but it has shifter bushings that deteriorate.
You have to cut off the third pivot point with a dremel, go to mazda, and purchase another shift linkage bolt on the transmission end (the larger of the two bolts) and matching nut (I got the nut at Ace Hardware for a few cents)
So six shifter bushings, one shift linkage bolt. The larger one on the transmission end.
That's the only way to get rid of the shifter "slop"
Power steering is a bit of a pain. look at the reservoir, make sure that the fluid is not low, and look at the hoses connecting to the reservoir. if you see wetness, then the hoses are leaking, and probably need to be cleaned and new clamps attached.
Otherwise you may just want to replace the pump. Mine went bad as well, and when it's cold it likes to fight with me, I turn it and it turns back, the little nasty bugger.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
October 21 2013, 8:19 PM
Also I see the terrible "double decker" console on your passenger floor. Take that picture down or you're going to get people hounding you to sell it!
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
October 21 2013, 8:36 PM
Great find on the mx , also welcome to the form lots of info here so take advantage . Doing a small tune up on the mazda will be a great idea help the mpg . Enjoy and keep us updated
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
October 21 2013, 11:22 PM
Profile YIM
Another "Ally" with an MX-3 in Michigan...well, shes actually in Kentucky at school (with the car) at the moment......
http://mx-3.com/phpBB3/viewtopic.php?f=46&t=80888&start=63
1993 GS SE - "slow" (Stock) - SOLD
1993 GS SE - "fast" (Curved neck KLZE, OBX headers, custom 2.5" exhaust, KL36 ECU, Exedy Probe GT clutch, KL36 LSD - the real one, Lantis Type R lefthand halfshaft - unfortunately worth mentioning)- SOLD
1993 GS SE - acquired 4/28/2013, SOLD February 28, 2015
1985 RX-7 GSL-SE - SOLD
2003 VW GTI 1.8T
2009 Mazda5 Grand Touring
October 22 2013, 9:11 PM
So I forgot to turn on reply notifications. I really like the color of her MX3! There's one that color in town but all the paint is peeling off the hood and I get sad every time I see it. There are three in Marquette as far as I know; mine, the sad purple one, and my boyfriend's old Herculiner'd one that was sold to a friend.
SuperK, that silly console thing drives me nuts! It came like that and was filled with Hot Wheels and a plastic dinosaur, so bonus, haha. I got the shifter taken care of, actually, along with a bunch of other stuff! I even got a titanium bushing (or something I can't remember the exact name) out of the deal, as one of them was gross. So obviously the solution was for my SO to machine a new one out of a titanium rod he had lying around. Way better than flowers, in my opinion. I'm posting the last few photos I took to my worklog now. It's like a whole new car with the new short shifter and the fixed power steering. And the timing belt. And new brakes. And rotors. And CV shaft :lol: It was a busy weekend. Still need to bolt on the new exhaust, though. Molly is currently without a whole one so you can hear her coming from a ways away.
I still need to do more 'tune-up' sorts of things. Oil change is the soonest, probably, but I feel a lot safer driving around now. Except now it has snowed and I realized I need good winter tires, as my driveway is a challenge.
November 23 2013, 2:33 PM
