View unanswered posts | View active topics It is currently May 26 2020, 2:14 AM
Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
 After fuel went over,engine problems
Post Re: After fuel went over,engine problems
Whats is that cel? Some time before I was able to make it with led
October 27 2011, 1:09 PM
where do you live? CEL is check engine light.
October 27 2011, 1:13 PM
In Lithuania (Europe). Everything was good but after I changed fuel filter the car wont start. So I think it isnt major problem.
October 28 2011, 8:08 AM
I figured out that car will runs good when the key is holding on the start position, but when I release it it will not. I tried change ignition switch but no luck. I read the internet that it can be the ballast resistor problem, but does mazda mx3 have one? Maybe someone can upload photo or tell where can I find it?
October 29 2011, 11:06 AM
Any help?
November 02 2011, 2:54 PM
You have a weird problem on your hands.
You should maybe start over on troubleshooting.
Does it spark? Does the pump run when the engine is turning?
November 02 2011, 3:12 PM
I writed that everything runs perfectly when key is on the start. just the fuel pump stops working if key released.
November 05 2011, 8:28 AM
Users browsing this forum: No registered users and 3 guests
