View unanswered posts | View active topics It is currently January 17 2020, 3:17 PM
Reply to topic  [ 12 posts ]
 NW oregon mx-3 projects
Post NW oregon mx-3 projects
Now that it's getting warmer and spring is finally deciding to show it's face I thought it would be cool if we could get a list together of things we want to work on and do either as a group or separately... just so we know what's going on with each other :D
For everybody:
Lexan for the hatches/ hatch installs
B-Pillar bars - I know we talked about this a while back
My list:
• Coolant system flush, adding water wetter
• Install SS brake line, master and slave clutch cylinders, replace brake pads,
• Brake system flush and replace with racing blue fluid
• Replace ball joints, get alignment
• Reprime race car (or flat black)
• PASS EMISSIONS :roll:
• Install new set of headers/ possible new muffler/ possible high flow cat if I can't pass emissions
• Make a true CAI by routing piping into front bumper
• When I get a new suspension system, installing that
• Install whiteline swaybar and wytbushings/ endlinks
• When LSD is ready, adding and rebuilding spare tranny
• Get DD running again... sigh :crying:
March 27 2009, 3:31 PM
Post Re: NW oregon mx-3 projects
For me.....
*Finish pulling dash out
*Gut doors and lexan the side windows
*Finish roll cage
*Install custom intake/new TB
*Finish car trailer to take the MX to the track!!
I gave up on passing emissions a loooong time ago. I would love to find another red MX3 and keep it just for DEQ and plate my turbo car!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
March 27 2009, 8:23 PM
Profile ICQ YIM WWW
Im in WA, so I'm pretty close
1. Need to do brake system flush (with speed bleeders installed it's a one man deal)
2. Clean up interior, haven't cleaned it since fall
3. Still trying to get SRD ebrake handle
4. Get new set of tires
March 28 2009, 1:41 PM
Profile ICQ YIM WWW
Wellll....I ripped the dash out...Literally. Its not going back in thats for sure!
Jarid Perry
April 09 2009, 12:03 PM
Profile ICQ YIM WWW
So, you used my "technique" :lol:
I'll write about my plans when I'm less frustrated with them. I finally found out that I need to pull the fuse for the alarm (which I don't know where it is), then disconnect the battery, to reset the cut-offs.. There are 3 fuses inline, and an extra fuse in the underdash box, so I'll pull them all, and see if it works.
April 11 2009, 4:42 AM
So am I! :shock: :?
April 16 2009, 11:17 AM
Profile ICQ WWW
Straighten front bumper a little
Install spyder headlites
HEI mod with coil
Alt being built to 120 amps
Complete body job and paint myself
Improve stereo
Replace Xmas tree air freshener
April 16 2009, 12:03 PM
Nd4SpdSe wrote:
So am I! :shock: :?
lol I finally just got one... although it's not as spectacular as I thought it would be (not sure what my expectations were)
April 16 2009, 7:39 PM
Beside putting in the hatch, I want to:
Get the thing running,
Install the wideband O2, and fine tune it,
Install Wytbushings,
Paint the car,
Finish the sound deadening,
Drive real fast.
Which reminds me; I need a Valentine Cop detector!
April 18 2009, 2:55 AM
Now I need to figure out how come it stumbles on acceleration ~2500-3500rpm, almost like there's water/air in the fuel line or something
April 18 2009, 12:33 PM
Profile ICQ YIM WWW
I just had this issue and it would hesitate between 3-4krpm - it ended up being my 7 nipple disti that was bad (or at least the pickups inside or something)... put in another one and it runs like a champ now!
April 18 2009, 12:51 PM
not sure we will have a work day if i keep diagnosing and fixing all ur guy's issues. except for marks non running mx3 :roll: stuipid car, maybe try ecu now :shrug:
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
April 23 2009, 12:03 AM
