View unanswered posts | View active topics It is currently January 17 2020, 2:55 PM
Reply to topic  [ 2 posts ]
 starting issues
Post starting issues
Hi,
Been having starting problems, the engine turns but there seems to be no ignition until you give it a little throttle then it'll turn over and then idle quite high about 1500 rpm till the engine gets warm then its fine, although it still won't start normally but quicker.
I read that if the mx3's are run out of fuel it messes the fuel injectors up, and this is what the car garage did before I bought it.
I'm yet to change the fuel filter but wondered if this has happened before or is there a way of resetting the ecu etc?
Any help is much appreciated.
Thanks.
October 03 2014, 4:34 PM
Post Re: starting issues
To 'clear' the ECU simply remove the + from the battery and hold the brake pedal down for 15 sec's or so. Have you checked the TPS, it could be way out of adjustment and could effect starting.
October 04 2014, 3:46 PM
