http://www.mx-3.com/phpBB3/
Specific target AFR for KLZE?
http://www.mx-3.com/phpBB3/viewtopic.php?f=50&t=80231
Author:  fowljesse [ October 17 2012, 2:12 PM ]
Post subject:  Specific target AFR for KLZE?
I say KLZE, because that's what mine is closest to. I know there isn't anyone else running the same setup with MS. I have been tuning, and screwing around with my AFR map, and was wondering if anyone has fine tuned (especially on a dyno) to find the best AFRs for power, and fuel economy.
My meter goes to 18:1, and that's what I cruise at for fuel economy. If I go more lean, there is a slight hesitation. For power, I've gone to about 13. Once I get the paid version, I'll datalog, and whatnot.
I would like to see VE tables of similar setups.
Author:  stereoking15 [ December 18 2012, 12:20 AM ]
Post subject:  Re: Specific target AFR for KLZE?
Jesse, anything higher than 16= bad, lean out condition can cause excessive heat and possibly burn a valve. At wide open throttle be around 12.5-13 afr is good. Cruising should be 14-15 afr.
Author:  MrMazda92 [ December 18 2012, 1:25 AM ]
Ask, and you shall receive:
http://forums.probetalk.com/showthread.php?t=1701288659
Page 1 of 1 All times are UTC - 5 hours [ DST ]
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
http://www.phpbb.com/
