View unanswered posts | View active topics It is currently January 21 2020, 7:09 PM
Reply to topic  [ 6 posts ]
 Mega Squirt III with V3.57 expansion
Post Mega Squirt III with V3.57 expansion
So I’ve been dealing with various ignition problems with my ZE. I decided to go the Mega Squirt route. I bought a MegaSquirt-III w/ MS3X Expansion V3.57 I haven’t seen any posts of people who have used this for both ignition and fuel. Has anyone done this? If so and you have a NA KLZE with performance exhaust (headers, hiflow cat and muffler 2.5 in tubing) and hi flow cold air intake, can you share your map? Any other tips and suggestions would be appreciated as well. Also if anyone has done sequential fuel injection for all 6 cylinders instead of just using 2 banks, I'd like to hear how that went and if it was worth the extra effort.
Thanks,
Rik
June 12 2012, 12:53 PM
Post Re: Mega Squirt III with V3.57 expansion
Hi, there. I'll share mine. It's pretty close to one I found on Google. The one I found is closer to what you have. Mine is a KLDE that has been rebuilt, including porting, and reworking everything, so it's a little stronger than a ZE.
Check out this thread: http://forums.probetalk.com/showthread.php?t=1701288659
June 12 2012, 1:46 PM
Thanks for the link Jesse, gotta dig through all the Turbo DE posts. Guess that's to be expected on Probe talk. Actually wish I had gone that route instead of the ZE. Did you do individual cylinders for the fuel injection on your setup?
Rik
June 13 2012, 10:20 AM
I'm not sure of MSIIIV3.57, I'm building a MSIIV3, but I can tell you sequential injection is a waste of time.
above about 3000 RPM, you will have NO noticeable difference between batch and full sequential.
Below that, you'll have more uniform wall wetting, and your A/F should be more stable at idle.
Basically not worth the effort. MAYBE a bit of tq down low if you've written a good tune to take advantage of it.
If you want to learn more, look into 'injection angles' and how to tune with them, and what you might get.
June 14 2012, 1:05 AM
Thanks Ryan, at this point I kinda just want to get everything back up and running as soon as possible, so I think you've convinced me to go with batch injection even though I originally chose this version of Mega Squirt because it could do sequential. I hope to get a lot of work done on the car this weekend also setting up the HEI mod with an external coil, so lots to do, I'll try and post a walk through of what I did when I'm done.
Thanks again.
Rik
June 14 2012, 10:48 AM
Let me know if you don't find a map that fits well enough, and I'll post mine.
June 15 2012, 1:18 AM
