View unanswered posts | View active topics It is currently August 05 2020, 3:05 AM
Reply to topic  [ 5 posts ]
 OBD 1 or 2
Post OBD 1 or 2
Hate having to ask this question. but im not sure if my 96 GS is OBD1 or 2.. cant find the connector anywhere.
Help?
lol thanks.
December 10 2011, 11:51 AM
Post Re: OBD 1 or 2
Look under the dash in behind the radio on the passengers side. You should see a plug with about 8 or so pins. Its right along the edge of the dash.
Additionally check the sticker on the drivers door frame or under the hood.
If you live in North America the car will definitely be OBD2.
December 10 2011, 11:57 AM
Post Re: OBD 1 or 2
found it.. wow its so obvious.
every time i had a reader around i couldn't find where to connect it.
thanks
December 10 2011, 12:47 PM
Post Re: OBD 1 or 2
Found 2 codes.
P0301 - Cylinder 1 misfire detected
P0400 - Exhaust gas recirculation flow
December 17 2011, 10:56 AM
Post Re: OBD 1 or 2
Misfires can be an elusive animal. Easiest start of course is to change the spark plug. After that checking then cleaning the injector would probably be next.
http://www.aa1car.com/library/misfire.htm
December 17 2011, 2:52 PM
