http://www.mx-3.com/phpBB3/
Coil Negative
http://www.mx-3.com/phpBB3/viewtopic.php?f=50&t=75018
Page 2 of 2
Author:  Jforce [ August 16 2010, 5:08 AM ]
Post subject:  Re: Coil Negative
yes thats the yellow/blue signal wire. That comment made me laugh hehe. I'm no expert either that wy i asked :P.
but B and C should be the same signal. both come from the coil negative. so i should be able to use either one of them, using a 1000 ohm resistor on the red wire or none on the y/b wire
apparently it seems to be that the C wires signal is not strong enough i've been told.
Quote:
" De kabel van je tellerhuis komt uiteindelijk van dezelfde plek af. Bij die 3-stekker is de rode de min, de middelste de signaalkabel voor je toerenteller. Probleem schijnt te zijn dat die signaal kabel soms geen sterk genoeg signaal geeft."
freely translated:
The cable of your instrument cluster eventually comes from the same place. At the 3-plug the red wire is coil minus, and the middel one (Y/L) the tacho signal wire. The problem appears to be that that signal cable sometimes doesn't give a strong enough signal.
Page 2 of 2 All times are UTC - 5 hours [ DST ]
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
http://www.phpbb.com/
