View unanswered posts | View active topics It is currently July 05 2020, 5:13 AM
Reply to topic  [ 5 posts ]
 V6 ECU chipped
Post V6 ECU chipped
Is a chipped ECU for the standard V6 1.8L MX3 transferable to any other MX3 with the same standard engine? Does the ECU have to be matched to a particular vehicle?
Any ideas?
April 30 2010, 8:24 AM
Post Re: V6 ECU chipped
You can swap ECUs.
Depending on what it's chipped for will determine how well it will work on another car. I can't imagine chipping an ECU for a stock K8 engine, but if that's the case, it'll work the same on any stock K8, assumming they're in the same shape.
April 30 2010, 4:45 PM
Thank-you for the reply. The chipping company said that I could expect 10% extra bhp even on a standard K8 engine.
May 02 2010, 12:45 AM
does it matter if its obd1 or 2?
well i dont have a obd2 mx. but i do got 2 obd 1 mx's
and ive herd that the ecu has another plug on it or something like that
SpatialTerror
May 02 2010, 1:40 AM
I'm using a chipped ECU from SKN-TUNING in germany.
I hava MX3 -92.
Seems abit more aggressive, should have 10hk more.
May 06 2010, 7:55 AM
