View unanswered posts | View active topics It is currently July 12 2020, 9:24 AM
Reply to topic  [ 7 posts ]
 Anyone else running e85 in there mx-3
Post Anyone else running e85 in there mx-3
Just wondering if anyone else is running E85.
My setup is as follows
Fuel system - Walbro 255 pump, stock lines, m-tuned miata fuel rail, 600cc deatschwerks pnp injectors, aeromotive fpr.
Engine management - I am useing a ms1 extra code, with vaf delete and idle control.
Engine - stock Bp-T swap,Ported Vj-20/Vf-10 hybrid, Custom fmic,HKS ssqv bov,Custom Downpipe with External wastegate dump,2-1/2in downpipe back straight pipe exhaust.
300hp and 330tq on Mustang Dyno with this setup.
93 Mazda Mx-3 rs,BP-T swap,22psi,custom fmic,Custom 2-1/2 downpipe with external dump,2-1/2in downpipe back exhaust,Tuned with Megasquirt on E85,Mazda protege G-series transmission,GS rear disk brake swap,H&R lowering springs,corksport front/rear strut tower brace. Dynoed at 300hp and 330tq Mustang dyno, 8.5@87mph 1/8mile http://www.cardomain.com/ride/3139490
93 Mazda Mx-3 GS,BP swap. Daily driver
January 13 2010, 6:21 PM
Post Re: Anyone else running e85 in there mx-3
Ok, I'm not running E85, but I'm very interested on doing so in the future. Can you tell me where can I learn how to define a system to be put on a KL-DE?
Thanks in advance. :)
Diogenes of Sinope.
January 13 2010, 6:57 PM
E10 8)
January 14 2010, 2:35 AM
I have not messed with the v6 engines at all yet about to turbo my brothers car this spring.
You should just need some bigger injectors not sure how big of injectors are avalible i actually need to figure this out for my bros car. The fuel rails for a probe or mx-6, probeaddictions has a rail kit, Then a better fuell pump a walbro 255 hp plugs right in just need a longer fuel line in the tank.
Then you will need something to tune the injecton and timeing to run e85. There is a guy on club protege that is about to make a pnp unit if you are not comfortable wireing it in yourself.
Thant should be all you would need to run a v6 on e85 reliably
January 14 2010, 2:14 PM
That's a start. Thank you. :)
Diogenes of Sinope.
January 14 2010, 2:32 PM
The biggest obstacle running E85 on a KL is getting the larger injectors. The best viable option is to run modified stock rails and high flow Nismo injectors. Those are rather pricey but are readily available. Beyond the Nismos I'd look into having a topfeed rail made.
With my experience in tuning KLs I wouldn't mess with E85 unless you're on a built motor and shooting for upwards of 500whp. There's plenty of much easier to tune and easier to obtain options to get you to 500whp. I've recently done some research into converting my own mx3 to E85, but decided against it.
February 24 2010, 5:09 PM
It's not about just getting more power. I want to run E-85 for environmental reasons, and because I can produce it myself.
The power benefits are just a (very welcomed) bonus. 8)
Thank you for the info on the Nismo injectors. I'll look into it when the time comes... :)
Diogenes of Sinope.
February 28 2010, 3:00 PM
