View unanswered posts | View active topics It is currently July 12 2020, 8:40 AM
Reply to topic  [ 9 posts ]
 instrument cluster interchangability '92 <> '94 V6?
Post instrument cluster interchangability '92 <> '94 V6?
My 1994 MX-3 project car has a crappy instrument cluster, the result of a poor attempt to install the electro-luminense (sp) replacement dials.
I have a 1992 cluster in greaat shape. Is it interchangable as is, or can I swap instruments/dials as needed to the '94 housing?
Or is this untread ground?
Thanks,
Jim
October 12 2009, 6:10 PM
Post Re: instrument cluster interchangability '92 <> '94 V6?
My car has a '92 GS cluster with a '94 RS dash harness and it's all good except wires might be in different places on the connectors. It was swapped when I bought the car, but I had to relocate the ACC wire for the clock, there might be more wires to change though.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
October 12 2009, 7:27 PM
and you may need to swap over the speedometer sensor. cable vs digital in 92 vs 94 for RS. although all gs were digital.
October 12 2009, 10:19 PM
If you have a V6, then yea they will swap right over, clusters have the same plugs. Only difference is that the 94 cluster does not have the stupid DAY option on it that. The 92-93 have the DAY option in the clock
October 12 2009, 11:45 PM
Thanks. I might try to move the speedometer, the '92 shows almost 100k more miles!
BTW, what is the DAY option?
Thanks,
Jim
October 13 2009, 11:23 AM
If you press the clock option ir will switch to a day/month format for a few seconds. This was stupid as some months have 30 or 29 days and the clock always went to 31. Lame
October 13 2009, 1:12 PM
Yeaaaa I never use it.
October 13 2009, 6:55 PM
I found switching my 94 cluster into my 92, the clock stopped working altogether...
October 13 2009, 8:37 PM
Read my post, I had to same problem. I just traced the ACC post on the back to the connector and found the wire was in the wrong place.
October 13 2009, 9:54 PM
Users browsing this forum: No registered users and 3 guests
