View unanswered posts | View active topics It is currently July 12 2020, 10:03 AM
Reply to topic  [ 10 posts ]
 radiator for a mx3 v6 will another type of radiator fit
Post radiator for a mx3 v6 will another type of radiator fit
my partner has an mx3 v6 not an import the radiator is gone and its almost impossible to find one is there any other type of radiator that will fit
September 28 2009, 2:29 PM
Post Re: radiator for a mx3 v6 will another type of radiator fit
No. There is no other vehicle that uses the same radiator. This question was asked only a week or two ago and could have been quickly answered with a search.
Another radiator could be made to fit with fabrication, but you can get a new replacement from rockauto.com for under $200.
September 28 2009, 3:03 PM
ok thank you i did try look im new to this im only looking for my partner the car is their pride and joy.
thanks for your help
ill look into it x
September 28 2009, 3:35 PM
Not true, the rad from a 626, mx6 and probably probe will fit with a bit of modification. You'll need to trim the upper rad support around the plastic reservoir, you'll need the lower rad hose with the T connector from the donor car, and the drain screw will dump coolant on the frame under the rad, but everything apart from that is perfect. You can probably run a thin hose to drain it properly, but I was lazy.
I've had a 626 rad on my car for a few months now without problems.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
September 28 2009, 7:37 PM
He said it could be made to fit with fabrication, which is exactly what you had to do.
September 28 2009, 7:48 PM
I wouldn't call what I did fabrication, fabrication would mean making your own brackets and everything, the only modification I did was trim the rad support.
September 28 2009, 7:50 PM
Are RS and GS rads the same?
September 28 2009, 7:52 PM
No.
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
September 28 2009, 8:47 PM
HA! I laugh in the face of your semantics! There is no other vehicle that uses the same radiator. True story.
September 29 2009, 1:13 AM
I know it's not the same, but it's barely different. But don't you agree with me? Just look up the definition of fabrication. :P
September 29 2009, 11:33 PM
