View unanswered posts | View active topics It is currently July 15 2020, 8:57 AM
Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 How can i slow my signal lights down, flashing too fast
Post
So i tryed switching the resistor that we talked about above and it made not difference. The stock resistor was a 51ohm, i tryed a 27ohm, 10ohm, 1.5ohm resistor and they all flash at the same speed. So
I need help to disable the load sensing circuit in my flasher so it will flash at a normal speed. I have installed LED turn signals and it flashs really fast.
September 27 2007, 8:31 PM
Post
I couldnt get the focus thing on my camera to work properly - but i took several images.
Basically there is a transistor (small black thing with three legs) in the circled area - you just cut the outermost leg.
September 27 2007, 9:15 PM
Post
Wow thanks for the help, that worked perfect. Definetly the cheapest and easiest route to fixing the problem. How in the heck did you ever figure that out.
September 27 2007, 9:32 PM
Post
Lot of vodka was involved :P
September 28 2007, 8:24 AM
Post Re: How can i slow my signal lights down, flashing too fast
i now this is one old a-- thread, but is this?!
i dont fancy buying 6 of those load resistors!!
August 26 2008, 2:03 PM
Just get higher viscosity blinker fluid.
August 26 2008, 2:24 PM
Post Re:
shameem wrote:
P.S. - I was ok with my leds flashing faster than normal till i got pulled over and "warned"......
yea i thought it was illegal so have fast blinkers...hyper blink
94 mx3 rs
92 mx3 gs curved neck klze SOLD
August 26 2008, 3:33 PM
