View unanswered posts | View active topics It is currently January 24 2020, 3:59 AM
Reply to topic  [ 11 posts ]
 Stereo Makes a humming noise each time i accelerate
Post Stereo Makes a humming noise each time i accelerate
Can somebody please advice where and how I sort out my stereo which makes a really irratating humming noise each time i accelerate it also gets higher in pitch!!!!!! driving me mad! somebody please help me get rid of this!! THANKS :D
August 26 2005, 4:34 AM
Post
1. check your grounding. most likely bad grounding that causes this.
2. if you have an external amp. check the gain level and adjust it down until you cant hear any humming.
nope-mx3
August 26 2005, 4:59 AM
Post Stereo Humming
Hello, thanks for the reply. Ok sounds like a good plan, but this may sound a it blonde but which earth do i check? behind stereo or in the engine bay???? also i do not have an amp.
Thanks! :D
August 26 2005, 7:40 AM
Post
The one to the stereo.
Theres also a good idea to ground the engine better also, as the stock grounding is pretty bad.
nope-mx3
August 26 2005, 9:51 AM
Site Administrator
Post
could be the power wire you used.
Keep this site alive! Donate!
August 26 2005, 10:23 AM
Post
This is caused by a ground loop
What is a ground loop?
August 26 2005, 5:25 PM
Post
Nice link johnnyb. Thx.
Image -Jim
August 26 2005, 6:50 PM
Post
np. People are always asking why their radios are humming on siriusbackstage.com and I just bookmarked that link to give them
August 26 2005, 7:17 PM
Post
on a side note you can also pick up a ground loop isolator at the following places:
USA: Radioshack
Canada: The Source
August 26 2005, 7:22 PM
Post Stereo Humming
Thanks all for your advice, much appreciated. Will let u know the results! damn you humming!!!! :D
August 30 2005, 8:30 AM
Post humming
i had the same problem with the humming its the grounding you have to get a thing for the rca inputs
1996 mx3 gs - so long
1997 Talon Tsi Awd - 350whp ya I wish
September 01 2005, 9:23 PM
