View unanswered posts | View active topics It is currently July 09 2020, 11:11 AM
Reply to topic  [ 6 posts ]
 Tap in to reverse lights
Post Tap in to reverse lights
So my reverse lights don't work so for temporary use I want to tap into an earlier point in to my reverse lights system in order to get the lights to work temporarily so I can pass inspection because its urgent
If someone can let me know where I can take the positive feedback from whether it be a line or a fuse to get a signal sense that would be great
03 Dodge Neon (rental i had for a month but i ran that into the ground for sure)
95 Chrysler Concorde (Junked my first car [still ran])
90 Nissan Stanza (Junked [wouldnt start one day])
89 Saab 9000 CD (sedan/turbo very fun but electrical problems[city towed away for no plates on private property])
94 Toyota Camry (mothers old car fixed it then broke it[dont ask] Junked)
93 MX-3 RS (My project for 3 years so far)
97 Honda Civshit (Beater/Stereotypical POS Honda im fixing)
December 22 2014, 9:46 PM
Post Re: Tap in to reverse lights
the reverse lights work off a sensor that attaches to the transmission casing.
The wires are prone to breaking off the sensor itself. Probably just need to replace the reverse sensor switch on the transmission.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
December 25 2014, 3:26 PM
Yeah I realized that after I went to look the connection was all green so I was going to cut it and redo it but it broke so I'm going to replace the sensor and try to find a way to make it so it doesn't break
December 27 2014, 1:26 AM
But I do have a question it won't harm the system if I put the wires backwards to the sensor right it just won't work as long as I know it doesn't do damage if I connect it incorrectly I won't have a problem I just want to be sure because the sensor plug was cut off
December 27 2014, 1:27 AM
The sensor has no polarity. Its just a switch. Doesn't matter which way the wires go in to it.
January 03 2015, 6:07 PM
Oh the sensor was bad it so it was all green s--- all over it on both the connector on the sensor
Now my signal wire wont start the starter I'm just going to run a momentary switch from the battery to the starter for now I got the relay and I looked at all the fuses but I can't find the relay all the fuses should be good so I'm assuming it's the relay I really need to get into some electrical soon but its really cold I just need to start the car go get the e brake fixed and go pass inspection before my car gets towed out of my apartments so much for the American dream
January 07 2015, 12:41 PM
