View unanswered posts | View active topics It is currently June 20 2013, 12:12 AM
Reply to topic  [ 2 posts ]
 Ignition Coil Wiring Diagram B6-ME
Post Ignition Coil Wiring Diagram B6-ME
Ultimately, we've got a question with the wiring of the coil and related components on the B6-ME. My scanner's not working, so bear with me.
The biggest question that we've got is, what does the orange lead to? I can't seem to find a good wiring diagram anywhere, even in the online manuals, let alone the Chilton's.
Any insight would be helpful.
90 TSi AWD; 550, 3" turbo back, MHI S16G, DSMLink, AEM WBO2, MBC @ 20 PSi, KYB GR2, Eibach Sportline, Strut Tower Bars, HKS Type 1, 1G Crushed BOV, VR Speed Factory FMIC, 2G Turbo Mani, Magnaflow muffler.
Girlie's:
93 MX-3 Base
92 MX-3 GS; KL-ZE swap, Maxxim 17's, Pacesetter catback (sounds awful), SRI.
February 19 2012, 4:12 PM
Profile YIM
Post Re: Ignition Coil Wiring Diagram B6-ME
Here's a picture of the relay that I'm talking about.
Still haven't figured out what everything leads to, especially the orange wire, as the only orange wire that is in the system runs from the distributor to the ECU.
Further down the line, the black splices to a blue wire, which in turn is connected directly to two other blue wires.
The white/black wire is spliced into the igniter yellow/blue, I believe. Have to double check.
What on earth could this relay be for?
Girlie's:
93 MX-3 Base
August 19 2012, 9:11 PM
Profile YIM
Users browsing this forum: Exabot [Bot] and 1 guest
