View unanswered posts | View active topics It is currently August 11 2020, 12:02 AM
Reply to topic  [ 7 posts ]
 323 gauge cluster in an mx-3
Post 323 gauge cluster in an mx-3
How hard would it be to swap the cluster from an 323f 97 model in an mx-3?
So that you can have illuminated needles......
February 03 2014, 2:44 PM
Post Re: 323 gauge cluster in an mx-3
97 would be an OBD2 cluster so your car needs to be 96 or 97. my 5 cents
February 03 2014, 10:21 PM
Don't think its been done... Be a pioneer and let use know how it goes..
February 04 2014, 1:39 AM
Hmm, yeah the digital distance counter could be a problem.
Als the sensor's etc. However the OBD-1 and OBD-2 mx-3 use the same cluster.
What about an mx-6 cluster?
February 04 2014, 2:59 PM
I just re-compared the two, a 92 vs 96. Both clusters look very similar but the circuit on the back lh side is different from one to the other as are the part numbers for each cluster. Just sayin.
February 04 2014, 9:41 PM
OBD 1 and 2 look very close to the same, but they are different... OBD1 and 2 wiring harnesses are comnpletely different in the Mx3's...
February 04 2014, 10:03 PM
Yeah knew about the wiring harnas.
But it probally won't work..
But new idea:
Xedos 6 :)
February 06 2014, 1:49 PM
