View unanswered posts | View active topics It is currently February 21 2020, 5:19 AM
Reply to topic  [ 10 posts ]
 94 MX3 heat/ac blower problem/noise
Post 94 MX3 heat/ac blower problem/noise
when i turn on my heat/ac the blower makes a huge racket. it sounds like a fan blade is hitting something. any ideas on how this can be adjusted/replaced/fixed?
youtube video of noise:
http://www.youtube.com/watch?v=efyfhkVYp5Q
p.s. not totally sure if this is in the right section so if its not mods please move
November 16 2009, 3:14 PM
Post Re: 94 MX3 heat/ac blower problem/noise
Pull the blower unit out and see what's going on. Just need to remove glove box and surrounding panel. Should be three 10 mm nuts holding the unit in place, and a plastic fastener holding the air duct to it.
'98 BMW 328is M-Tech
Feedback Thread
November 16 2009, 5:09 PM
hehe sounds like you have a extra motor in your car :P
my fan is doing the same thing, but not that bad, but I'm
too lazy to take it out and looking at it :)
November 18 2009, 9:18 AM
I swear years ago I saw a replacement fan assembly online somewhere. Not that bad $-wise IIRC...
93 MX-3 BP - Worklog
November 19 2009, 2:25 AM
bump from the past.
finally got around to looking at it today. pulled the blower motor out and what did i find?
heres all that garbage dumped out:
it runs like its brand new now and all noise is gone :)
June 03 2010, 2:45 PM
Those leaves will keep coming back, because there's no cabin filter above the blower.
Feedback Thread
June 03 2010, 4:02 PM
another good reason to install a filter...
June 03 2010, 11:49 PM
the best part of it is that all those leaves are from trees that were around the drive way from where i bought it.
no maple leaves found :P
June 04 2010, 5:53 PM
I have the same problem also with a noisy fan; however, when I turn my fan up not only does it make a lot of noise, but I get a strong rubber smell (almost like something is burning)
August 22 2014, 2:20 AM
could be the fan motor seizing up
August 22 2014, 5:20 AM
