View unanswered posts | View active topics It is currently June 03 2020, 11:11 AM
Reply to topic  [ 15 posts ]
 MX3 traction bars - Installation Howto
Post MX3 traction bars - Installation Howto
Ever since I got my MX3 I've wanted to make some traction bars for it just like I had on my probe. I got in touch with janz99 from Probetalk and he agreed to make me a set if I sent in all the measurements.
These things are great. Really straight forward install and they work wonders for wheel hop. Especially for those that don't have aftermarket LCA bushings.
Pretty much just undo the ball joints, remove a stud, drill a hole, and you're done. I made a howto on the install. There's pics where necessary. Click on any of the pics for fullsize versions.
1) Get car up on jackstands and remove the wheels.
2) Remove the LCA bolt closest to the engine. Really long 17mm bolt. Place Traction Bar bracket on and replace using stock hardware.
3) Unbolt ball joint from control arm. Should look like this when you get done.
4) Remove the stock stud for the ball joint. I used a hammer. It should be in there pretty good, but after some convincing it pops right out. You'll be replacing this stud with a longer bolt to make room for the traction bar bracket. (included with tbars)
Here's a pic of how the ball joint and Traction Bar bracket will line up.
The spacer shown in the pic goes on top of the control arm over the hole where the stud was.
Here's the bracket bolted onto the control arm
5) Now it's time to drill the hole for the other Traction Bar bracket bolt. This bolt is there to make sure the bracket doesn't slide around under load. Make sure your bracket is in place so the washers don't over lap each other. Then drill the hole thru the LCA. If you don't have the right size bit you'll have to open the hole up a little further. Make sure you remove the bracket before doing this so you don't damage it.
Pic of the hole all drilled and ready.
The bottom should look like this once everything is all bolted down.
6) Now just attach the heim joints to the brackets and tighten it down. Make sure to have the joints extended a little out of the threaded rod when you do your install. This will allow room for adjustment once you're done.
August 10 2008, 8:51 PM
Post Re: MX3 traction bars - a reality
Nice write-up!
I haven't seen these on an MX-3 in about 3 years.
August 10 2008, 8:57 PM
We're gonna work on a bulk buy. These are made specifically to fit MX3s.
August 10 2008, 9:00 PM
What else do these do besides prevent wheel hop off the line?
August 10 2008, 9:11 PM
what else you want them to do? this is for drag racing applications only. if you want to decrease your R/T and improve your 1/4 mile you should get these.
August 10 2008, 9:37 PM
Profile ICQ YIM WWW
Under really hard acceleration inertia acts on the mass of the car attempting to keep it at rest while the wheels are trying likehell to go forward really fast. The control arm bushings would tend to deform and allow the control arm to deflect forward. The traction bar links the control arm to the frame of the car preventing it from changing the geometry of the suspension on hard acceleration.
That's my take from the point of view of someone who doesn't actually know.
August 10 2008, 10:34 PM
You know, I've wanted these things since I've gotten my ZE in.
Honestly tho, I'm surprised a traction bar that runs parallel to the control arm actually works. You'd think you'd want it to run an an angle (ideally parallel, but that's not possible unless you want to restrict the LCA's up-down movement) to use the torsional strength of the bar. It would work if you had joins with no horizontal movement, but those joints do have some pivot ability, as well as the bar may have some flex relying on it's ability to resist flex/bending to strengthen the LCA.
However, if hppwdn says it works, I'd believe it and more likely would get in on a set.
August 10 2008, 10:37 PM
Profile ICQ WWW
Man I'm really out it. That write up was great. I thought wheel hop was a result of poor suspension, usually springs that are too soft and shocks that are too mild mannered. This is a new concept for me. Everyday is an education that's for sure. How can I tell if I have wheel hop? So far if I accelerate aggressively all I feel is the wheels breaking loose and spinning. Use to be with rear wheel drive you'd feel a banging sound.
August 10 2008, 10:51 PM
Wheelhop is actually generated from the the control arm moving front to back while the tire is trying to catch traction. These prevent the control arm from moving front to back under load. It's actually the same theory the original PMO bars worked on. Just in a much smaller package. The probe guys have been running this style for a few years.
August 10 2008, 11:10 PM
Probe guys? I haven't heard of a single Probe that has done anything other than occupy space in a parking lot. So as with Ford now and then their Lame city. I saw this guy the other day with 5.0 on the side of his 71 Mustang. What an idiot, we didn't even use metric then. He started off quick but backed off when I left him in my rear view. Next!
I respect your tech, I just have no time for Probes in our forum.
August 10 2008, 11:21 PM
:confused2: If it makes you feel better take out probe from everything I typed and replace it with MX6. It's the same car. They both have Mazda KL engines and were both assembled in the Flat Rock Michigan plant. Except the probe had much larger production numbers. And that is why most people say probe when referring the probe/mx6 platform.
btw: my roommates probe (which is my old one) runs a 12.6 at 116 boosted on a stock DE from the junkyard and street tires. So at least one probe is doing something other than sitting in parking lot.
August 10 2008, 11:33 PM
The probe guys have been running this style for a few years. Respect for your tech but we don't care what the Probe guys do. 12.6 and street tires. OK
EDIT: No disrespect intended, the probe guys thing didn't fit well. Your tech is 100% and I thank you for posting it.
August 10 2008, 11:43 PM
No big deal, I just found your probe comments a little odd. Since we share the same engine I've always considered the Probe/MX6/MX3/626/Millenia world one big family of cars.
August 11 2008, 9:38 AM
Post Re: MX3 traction bars - Installation Howto
I have to say that if you spend a bit of time on PT those guys have done way more with the K family of engines than we have. I don't like the tone of their forum and I think there's a lot of guys there with big chips on their shoulders, but they have figured a lot of stuff out just through sheer volume of members. If Mazda had made 3X as many mx-3's as they did we'd have Probe like aftermarket support and we would be light years ahead of where we are. Projects like this traction bar setup are really important. If we want cool stuff for the MX-3 we have to make it ourselves.
August 11 2008, 10:49 AM
If it wasn't for the Probe/Mx-6'ers, we wouldn't nearly have the mods available for the K-series motors that are current available, we own it to them
I agree, and I think most of us think the same way.
August 11 2008, 11:04 PM
Profile ICQ WWW
